oxygen sensors
however, correct me if im worng....
If he was to get a aem uego it should come with a wide band sensor with it so you can get a much better reading then the stock sensor would ever give you would just have to drill a hole in your exaust pipe weld in a bung and screw it in.... just like this unit...
http://modernperformance.com/all/aem...wideband.shtml
it comes with the sensor.
if you use the narrow band the gauge will oscillate and you will be left wondering where exactly the a/f really is. And with turbo's you might have a spike somewhere in your power band that may only happen for 300 rpm while accelerating and the narrowband would compleatly miss the event...where the wide band gives you real time.
