Turbo people help. Garrett T3
Old Dec 7, 2007 | 04:50 PM
  #91
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default RE: Turbo people help. Garrett T3
i am not a hundred percent sure if turboing a first gen is like turboing a second gen, u will not be able to run stock injectors and fuel reg and get a good tune, the second gen takes a fourty lb injector, stock r 19, and a bigger pump torun decent, along with a fuel management system, such as MS...first gens may be alittle different, but i would rather be putting in a set of 200 dollar injectors, rather than a 350 dollar engine,(leaning out is a very bad thing)for one the injectors take all of ten min to change, and and engine can take a few hrs..... good luck
Old Dec 7, 2007 | 05:35 PM
  #92
12 volt's Avatar
12 volt
ORIGINAL: 95to96transplantneon
turbo nipple as seen here.
find me aGOOD pic of your wastegate...if you have to find one on ebay do it ...
[IMG]local://upfiles/61619/0828D0F267DB4E9F8BAEB979D7B45DFD.jpg[/IMG]
his turbo has an internal wastegate
this link explains the diffence
http://www.myturbodiesel.com/1000q/turbocharging.htm
