changing cam seal
Alright the oil is leaking around the cam seal we figured it out. So what all do you have to do to change it? Do you have to remove the cylinder head? What all gaskets will I need to buy? Just give me all the info on what will have to be done so I can relay it to my sister. She is trying to figure out if it is worth fixing, because its in pretty bad shape and she doesn't want to put a ton of money in it. Thanks for the help
need to remove the alternator and powersteering blets, crank pulley, motor mount bracket, front timing cover,timing belt, idler pulley, cam sprocket, then the rear timing cover.....
Can You give me a list of what will have to be replaced when I take everything apart? Likeif I'llhave to replaceseals behind the crank pulley, or any other pulley, and the timing belt. Anything that should be replaced when replacing the cam seal will someone list for me so I have a list of parts for her to get? Thanks for the help guys!
