wiring question
Old Jan 15, 2008 | 08:57 PM
  #21
95to96transplantneon's Avatar
Default RE: wiring question
oh **** sorry yes it will work for some damn reason I thought you had a dohc... got my threads crossed. but yeah if your getting the parts car I would you can sell most of it or just replace anyparts that are better on the doner...
ok this is were I'm not 100% sure of... I know that some of the sensors are not going to work on your 95 motor, I'm really sorry I dont know witch ones... what you do is
1)get the wiring harness out of the doner car labeling with tape and a marker where everything came from as you go.
2) Start installing the 98 harness on your car. Start at the top and work your way down. It helps alot if you take your intake manifold off...Well your going to have to do that anyways.
3) At some point your going to come across a sensor that justwont plug in becuase of it being a different plug... Same sensor just different plug...
4) When you come to one of these sensors remove it from your 95 block and replace it from the 98 doner car...
5) your going to have a plug coming offwhere the fuel injectors are that you going to have left over this will be your map/iat sensor... the new one that the 95 had 2 seporate sensors...
I hope this makes sence... If you need a pic of what the map/iat sensor looks like let me know and I'll go take some pics of the sensor and the plug that goes into it...
if this dont make sence... let me know It dont make sence to me really lol
