turbo
Old Dec 7, 2004 | 02:15 AM
nightstreetneon's Avatar
nightstreetneon
Default turbo
I'm getting a turbo for my car 98 manual this winter. the guy said i didnt have to replace anything in my engine as long as i used a 9 shot. is this true. i dont know much of anything about turbos and i am just making sure that everything will be ok.
Old Dec 7, 2004 | 02:18 AM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: turbo
A 9 shot? Do you mean only run 9psi of boost? But yeah, I've heard the motor can handle around that amount of boost without doing anything extra to the motor.
Old Dec 7, 2004 | 02:41 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: turbo
You'll be fine on 8-10 pounds of boost on stock internals.
I do however strongly suggest a cam and valve springs regardless.
Do you have a DOHC or a SOHC?
Old Dec 7, 2004 | 12:59 PM
nightstreetneon
Default RE: turbo
yeah i meant only 9lbs of boost. sorry. what cam and valve spring should i get? i have sohc
Old Dec 7, 2004 | 04:51 PM
casper's Avatar
casper
Default RE: turbo
either the Crane #12 OR #14, don't forget to get valve springs too.
Old Dec 7, 2004 | 11:27 PM
Cr@zy Squ33
Default RE: turbo
A 14 is a very aggressive cam. Its great for turbos. The 12 is fairly aggressive but its more of a streetable cam.
Old Dec 8, 2004 | 01:36 AM
elric62285's Avatar
elric62285
Default RE: turbo
Hey Crazy, speaking of cams, would a 14 get me anything over a twelve w/ my engine set up? Any other oppinions would be great!
Old Dec 8, 2004 | 01:46 AM
Cr@zy Squ33
Default RE: turbo
Yes. But be prepared to break stuff with the 14 with your current setup. Its very aggressive and lopey.
Old Dec 8, 2004 | 01:48 AM
elric62285's Avatar
elric62285
Default RE: turbo
Like what? and how?
Old Dec 8, 2004 | 02:24 AM
Cr@zy Squ33
Default RE: turbo
Mainly mounts.
