need help deciding
Old Jan 15, 2008 | 05:09 AM
rayraydoet's Avatar
rayraydoet
Default need help deciding
ok im guna do a build i cant decide weather to get a magnum a dohc or wawat i got. i cant decide weather to go lonng rod or not and because im having problems with the pcm i want a plug and play standalone any one no where i can get one? does aem make one or can i use the greddy e mange?? and caan i get a dohc afx pcm for a sohc motor and it run fine? i was thinking of puting in a dohc motor later is that ok to do? if not i want a plug and play standalone that i can tune to the max help me out im guna want a all out n/a car. so i want the to get a programable pcm. the afx u cant get a new chip and install it when u want new things or get it dynoed with out a standalone
Old Jan 15, 2008 | 12:01 PM
12 volt's Avatar
12 volt
Default RE: need help deciding
have you looked intomegasquirt? might not be plug and play but for the money much better that anything else.
everything you would what to know about MS
http://www.diyautotune.com/faq/faq.htm
Old Jan 15, 2008 | 01:07 PM
rayraydoet's Avatar
rayraydoet
well so that megan thing is a exu tunable but i got to cut up the hole harness and splice theres on? nothing around piggy back that does ignition curve and fueol curve? AEM dnt make a plug and playt
Old Jan 15, 2008 | 02:21 PM
protivakid's Avatar
protivakid
ORIGINAL: rayraydoet
...What? not to be mean man but I have no clue what you just said... "megan thing"?
Old Jan 15, 2008 | 02:34 PM
neoncrazy101's Avatar
neoncrazy101
if your not planning on going turbo, and just want either the Dohc or the SOHC, get either the AF/x PCM or the Mopar Performance PCM. those are straight plug and play. and no, AEM, nor Megan makes PCMs for the Neon...nor "chips".
Old Jan 15, 2008 | 02:47 PM
rayraydoet's Avatar
rayraydoet
ok well i was going to build a mega squirt. but what one should i use and what items are a nasetity to have?and my neon is atx so i got to leave the old computer in to control it? help me out here.
Old Jan 15, 2008 | 03:55 PM
rayraydoet's Avatar
rayraydoet
i have sohc now if i want to go dohc and i buy a afx i cant get it reprogrtamed can i?? so can i run a dohc pcm from afx on a sohc untill i can aford to build a 12 to 1 comression and dohc heads all done up?
Old Jan 15, 2008 | 04:00 PM
95to96transplantneon's Avatar
Ok heres the deal.... MS will control your auto... if you build it hp will come... lol had to do it.... however you must be very very knowledgeable about every aspect of a gasoline engine theres no room for error, however they have made it better now with there .v3 where if you happen to tune it to the point of being lean and if the a/f ratio goes to a predetermed point it will make the neccicary corrections to bring your a/f up to a safe level... it isent plug and play but if you have a good engine wiring harness diagram and your able to read it well then you should be fine....
The af/x does make a auto version for your car... but as far as putting a DOHC computer on a SOHC neon your flipping mad... the af/x dumps tons of fuel, like say goodbye to gas mileage if you have a hevey foot... if you added a dohc you will have gas coming out your gas tank... you will have to remove your cat due to how much the race pcm advances your timing it will burn your cat down to the ground... so if you live in california or any other state that you have to get inspected... your screwed... The nice thing about the af/x computers are they have the ability to re learn your driving habits and make corrections to what your doing... heres the description of the race pcm...
Race computer specifications:- 7800 rpm redline (maximum possible!)- Totally new spark and fuel maps- Automatic speed control may be set up to 120 mph (if so equipped)- No mph cutout whatsoever- Able to use aftermarket coil and/or ignition system and not turn checkengine light on. Great for drag-race type "staging" systems.- Does not go excessively rich at top-end to "save" the catalytic converter,resulting in vastly improved maximum vehicle speed.- Significantly de-sensitized detonation sensor for use with noisy valvegear, header, etc.- calibrated for use with header and no catalytic converter. Does not readthe downstream O2 sensor, which may be disconnected w/o turning on checkengine light. May melt down a catalytic converter if used!- Best results obtained with uprated cam (Crane #16 or more), head work,larger throttle body, ported intake, etc.- Ability to use aftermarket coil and/or ignition system and not turn checkengine light on. (Year 2000 computers only).- Typical flywheel HP increase 15 - 44 HP (depending on other mods)- Warning: at the RPM this unit is capable of, you should have 2001-uprocker arms / lash adjusters (DOHC), and stiffer-than-stock valve springs toprevent valve float and resultant damage!- Requires 93 octane fuel (at altitudes up to 4,000 ft.) or octane booster.More octane required with compression increase.- Very wide ability to adapt to modifications as you make them.
however they are very expensive... I see used ones go for around 330 or so but they go fast. And since you dident mention what year neon you have I want to remind you that they do not make a af/x for a 95.
Old Jan 15, 2008 | 04:22 PM
heres the best place for neon guys to get a MS... they have a super 420a version.... I know we literally dont have 420a's but its the same thing... other then the head..
http://www.rs-autosport.net/catalog/
Old Jan 15, 2008 | 05:09 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
yeah, ms is the way to go, E MANAGE sucks, did one for a guy on an eclipse, and i will never use that system again.....
