View Poll Results: A poll
Voters: 7. You may not vote on this poll
To sell or not to sell...
i have a problem once and a while with my red r/t....one of the connectors to the pcm has a broken clip to hold it on and a loose wire...turn the ignition on...no spark, no fuel pump, no check engine light....i pop the hood and wiggle the connection and it works fine
when the ignition is on do you hear a buzzing comming from the pcm???
go though the connector to the pcm and give each wire indivigually a little tug....sumtime the wires can break inside the plug.....just to check...
i will think of more....it just may take some time
