no spark..everybody says they get it fixed at a shop but never tell what it is
Old 02-05-2008 | 01:07 PM
pssssst's Avatar
pssssst
Default no spark..everybody says they get it fixed at a shop but never tell what it is
ok i havent had spark in my neon for 6 months and kinda forgot i owned the car... i have seen countless posts on "no spark no spark" and people always say they either get it fixed or take it to a shop and get it fixed and then never tell what was corrected to make it run!! please anybody who hasnt had spark and got it fixed tell me how and what you did because i will try everything until this car runs thanks
Old 02-05-2008 | 02:52 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default RE: no spark..everybody says they get it fixed at a shop but never tell what it is
have u changed the coilpack, if not try that, or the harness going to the coil pack.......
Old 02-05-2008 | 03:37 PM
95to96transplantneon's Avatar
ok psssst try this for me...
take you multimeter out to your car, and disconnect the clip to the coilpack... now put the red lead into the middle wire and ground the black lead to the car... put the key in the run postion, the middle wire should read 12 volts, or close.
then take a test light and insert it into one of the other two outside wires, making sure to ground out the test light wire to the car... then have someone try to start the car you should see the light flashing at a steady rate while the car is trying to turn over... make sure you test both of the outside wires...
If you do not have a flashing light or 12 volts then go to your pcm if you have a....
95 test pin 1 and 21 with your test light this is where the wires you just tested at the coil pack connect to the pcm see if anything changes... then check pin 11 to see if there is 12 volts.
If you have a....
96-99 test pin 2 and 3 with the test light, and i cant figure out what the 12 volt feed is on the harness... sorry. but you will be testing the left plug in your pcm.
do that and see what is up...
Old 02-05-2008 | 04:30 PM
Jr. Mechanic's Avatar
Jr. Mechanic
ORIGINAL: 95to96transplantneon
If you have a....
No, you put the other end of the test light to the POSITIVE side, not the ground for testing the two outer wires. And input to the coil should be between 10 and 11 volts usually.
Old 02-05-2008 | 04:39 PM
a test light will work ether way... it would just be easyer to stick the pointed end in the harness and then ground the clip...
Old 02-07-2008 | 03:00 PM
pssssst's Avatar
pssssst
ok.. i tried the plug to the coil and did the "screwdriver" spark test... the car isnt getting spark to the wires or even the coil pack plug... i havent tried the pcm yet because we got like 6 inches of snow right after i read this post so i will try that next.... i mean if im not getting power to the pcm what else could it be?? thanks guys
Old 02-07-2008 | 03:47 PM
Jr. Mechanic
No, you have to put the clip on the positive side, the PCM sends a ground signal through the black/gray and blue/tan wires.
Old 02-08-2008 | 03:04 PM
pssssst's Avatar
pssssst
my starter ground wire is lightly smoking at the starter... any help on diagnosing my prob???
Old 02-09-2008 | 02:42 PM
unclemike's Avatar
unclemike
did you try to retreive the fault codes with the ignition switch trick?
Old 02-09-2008 | 04:08 PM
12 volt's Avatar
12 volt
ORIGINAL: pssssst
Usally resistance will give you heat. check the connection and make sure the contacts are clean. For the no start condition i would just go thru the wiring and make sure the grounds are good. Try and narrow down the problem some how.
a test light will work ether way.If your useing a volt meter the voltage will read negitive if the polarity is switched.
Quick Reply: no spark..everybody says they get it fixed at a shop but never tell what it is
