WANTED intake manifold
Old Feb 5, 2008 | 07:59 PM
dcmcguy's Avatar
dcmcguy
Default WANTED intake manifold
I need an aluminumintake manifold for my sohc, the junkyard wanted $100, i told em to f*** off...is that a bad price, i thought it was, anyways , get back to me
Old Feb 5, 2008 | 08:14 PM
spudsterier's Avatar
spudsterier
Default RE: WANTED intake manifold
the aluminum ones usually dont go very cheap....even on ebay
Old Feb 5, 2008 | 08:48 PM
95to96transplantneon's Avatar
40-45 at the most let me try to find one for you.... you should stick with plastic really unless you want to do a box manifold. the aluminum ones heat soak pretty bad causing you to lose hp really due to warmer air charge...
Old Feb 6, 2008 | 10:20 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Heat soak is not a major issue for aluminum intake manifold. Hotter air combusts better than cooler air anyway. Though cooler air reduces the chance of detonation, it also requires more fuel to be used efficiently. The aluminum sohc manifold is only best for itb or box manifold use. $100 is a touch pricey, but you get what you pay for. How far do you plan on taking your neon?
Old Feb 6, 2008 | 02:57 PM
12 volt's Avatar
12 volt
yes hotter air detonates better.dont underestimate the power of air density
Old Feb 6, 2008 | 04:20 PM
tranyinstaller's Avatar
tranyinstaller
your funny ghost. although heat soak isnt THAT big of an issue, on the topic of air temp. colder is better (to acertain point). of course im alwayse thinking in terms of power. you are most certainly right about the fuel eco. though.
Old Feb 7, 2008 | 07:18 AM
dcmcguy's Avatar
dcmcguy
yea, i want another one, because i'm going to make a box manifold...
Old Feb 7, 2008 | 10:05 PM
rayraydoet's Avatar
rayraydoet
any one got pictures of custom box manifolds so i can see what it looks like. why is it called a box mani? is the intake a box with no runners or sumthing? i was guna custom make a plastic one im guna see what used manis i can buy to experment with.
Old Feb 7, 2008 | 11:09 PM
heres my All Motor Mike box manifold...
god damn it would someone please explain what the hell im doing wrong...
Old Feb 7, 2008 | 11:12 PM
here since the damn link wont work...
[IMG]local://upfiles/61619/6F7A95BC6A1F4C4CAE1D8D34170AE895.jpg[/IMG]
