engine removal assitance needed!!!!
Old 02-15-2008, 04:54 PM
rayraydoet's Avatar
rayraydoet
rayraydoet is offline
Default engine removal assitance needed!!!!
hey guys. i blew a rod yesurday so im taking my engine out fo the car. i removed the steering pump alt, intake mani all the trans bolts harness off and fuel lines my engine is siting on my cherry picker. but i cant get the engine out because of the torque converter. how do you guys manage to get the engine out with the converter on it?? any sugjestions needed as im trying to get it out to i can put it on my stand to see if the engine is slavigable please help
Old 02-15-2008, 05:58 PM
95to96transplantneon's Avatar
95to96transplantneon is offline
Default RE: engine removal assitance needed!!!!
do you have a load leveler where you can tilt the transmission side way down and then lift it out???
Old 02-15-2008, 06:28 PM
rayraydoet's Avatar
rayraydoet
no i got it out tho i unbolted the converter and pulled the motor out
Old 02-15-2008, 09:05 PM
Slashwannabe's Avatar
Slashwannabe
Slashwannabe is offline
OMG just un bolt the fkn torque converter from the flex plate. ITs real easy to take off then. put ratchet or wrench on the engne crank pully and hold it still while unbolting the torque converter from the flex plate.
After doing that the Motor should pop out faster than Ron Jeremys **** at a Gang bang 500.
Old 02-15-2008, 09:10 PM
Slashwannabe
OOPS I was late with my reply....sorry
Old 02-15-2008, 10:05 PM
rayraydoet's Avatar
rayraydoet
ash you crack me up. lol . the engine the piston 4 it totally disinagrated in to millions of pieces. i geuss the weakest link of neon are the stock pistons. the rods probly handle the abuse. im guna post pictures of the piston and the clinder the pin is still in the rod lol.
Old 02-15-2008, 11:09 PM
12 volt's Avatar
12 volt
12 volt is offline
that should be a good pic "save as" material
Old 02-15-2008, 11:36 PM
rayraydoet's Avatar
rayraydoet
this is the oil pan and the piston. ahaha no long a piston lol
[IMG]local://upfiles/81398/6293BA6883B24026A8B1F92089FF47F5.jpg[/IMG]
Old 02-15-2008, 11:37 PM
rayraydoet's Avatar
rayraydoet
this is the rod with the pin in it still lol
[IMG]local://upfiles/81398/34480703124D469E91BA86CDD760D80A.jpg[/IMG]
Old 02-15-2008, 11:39 PM
rayraydoet's Avatar
rayraydoet
number 2 pic of rod an clinder wall
[IMG]local://upfiles/81398/DC393584496041D082B70829D1EEE00D.jpg[/IMG]
Quick Reply: engine removal assitance needed!!!!
