cold weather tick
Old Dec 25, 2004 | 09:46 AM
moparturd's Avatar
moparturd
Default RE: cold weather tick
ORIGINAL: showorgo?
what kind of oil would you reccomend?
Actually a thinner oil would work better. 5W - 30 flows better than 10W when cold.
Both of my Neons, 96 and 01 SOHC had the same tick when cold. I never did try the thinner oil, but probably should have. I did get 110K on my first Neon before I sold it.
Old Dec 25, 2004 | 12:35 PM
showorgo?'s Avatar
showorgo?
it does go away after the car runs for a while. its a relief though to know its not something to worryabout. it is incredibly annoying though. thanks for the info.
also, im pullin some codes on the car.
12 - direct battery input to pcm was disrupted in last 50 key on cycles (do i have to reset the PCM?)
21 - 02s sensor problem (oxygen sensor), upstream or down stream
any idea how to fix these.
Old Dec 25, 2004 | 02:15 PM
Cr@zy Squ33's Avatar
Cr@zy Squ33
ORIGINAL: mopartodd
ORIGINAL: showorgo?
Yes, a thinner oil does flow better but it doesn't coat the rockers and valves as well as a heavier oil. In the winter you should probably use a heavier oil.
But yes, all Neons have a valve train tick. There really isn't much you can do about it some Neons are louder than others. If you experience performance issues then you can replace the rockers.
