sway bar bushings
Old 03-16-2008, 01:23 AM
Spawne32's Avatar
Spawne32
Spawne32 is offline
Default sway bar bushings
im unsure which to purchase, advance has two sizes and it doesnt specify which one i need, 20mm and 22mm.
Old 03-16-2008, 02:09 AM
fsu182's Avatar
fsu182
fsu182 is offline
Default RE: sway bar bushings
if you have a standard neon (non r/t or acr) than its probably the smaller bushings. im pretty sure the front swaybar is smaller on the rest of the cars.
Old 03-16-2008, 02:43 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
DOHCgarrett t3 is offline
front or rear? and front is always larger than rear
Old 03-16-2008, 09:22 AM
Spawne32's Avatar
Spawne32
Spawne32 is offline
front
Old 03-16-2008, 09:29 AM
neoncrazy101's Avatar
neoncrazy101
neoncrazy101 is offline
according to energysuspension, front would be 20mm and rear would be 16mm. unless u have like an ACR or R/T (i think), then it would be 22mm up front
http://www.energysuspension.com/pages/cry3.html
Old 03-16-2008, 10:17 AM
Spawne32's Avatar
Spawne32
Spawne32 is offline
what is an ACR and how do i find out if i have one, its a 1998 highline sedan
Old 03-16-2008, 12:24 PM
DOHCgarrett t3
thought it was 19mm up front?
Old 03-17-2008, 12:42 AM
Spawne32's Avatar
Spawne32
Spawne32 is offline
nobody still knows what size?
Old 03-17-2008, 01:10 AM
DOHCgarrett t3
Old 03-17-2008, 01:57 AM
95to96transplantneon's Avatar
95to96transplantneon is offline
whats your vin I'll check if you have an acr...
its 22 up front for acr/rt and 20 for highline expresso and lowine and baseline...
Quick Reply: sway bar bushings
