coil over install
Old Mar 17, 2008 | 01:56 AM
VegasMagnum's Avatar
VegasMagnum
Default coil over install
ight so a homie of mine just ordered some ebay coilovers cause hes ballin on a budget... at least i talked him out of cutting his stock springs that have over 120k on them... well that being said... does any one have a write up on these? the reason i ask is because im not sure if the sleeve sits on the stock spring seat or do you have to cut the seat of so it sits all the way at the bottom of the strut???? i did this on a 97 cutlass supreme i had and you had to cut the seat in order to do the coil overs ...
Old Mar 17, 2008 | 03:41 AM
12 volt's Avatar
12 volt
Default RE: coil over install
the genral consensus one the ebay coilovers is thatits acrapy product.because of this i dont think there is a write-up.
Im sureif you've done anouther set before these shouldnt be that hard.
Old Mar 17, 2008 | 09:59 AM
spudsterier's Avatar
spudsterier
i wouldnt waste thetime putting these things on any car....i had them a while back and they were the biggest pieces of **** i ever bought...
no write up that i know of
Old Mar 17, 2008 | 10:47 AM
I_Ride_Neon's Avatar
I_Ride_Neon
I will give you a write up. Put the adjuster at bottom. Use the rubbers bushing between the adjuster and spring. Use the cap that comes with it for the top. But rubber seals between the spring and cap and between the strut and the cap. Put it back together using haynes manual.
Old Mar 17, 2008 | 12:59 PM
VegasMagnum
but you dont have to cut the oem spring seat?
Old Mar 17, 2008 | 05:22 PM
spudsterier
no
Old Mar 18, 2008 | 02:22 AM
VegasMagnum
thats all i needed to know thanks
Old Mar 18, 2008 | 02:19 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
ghetto.
