look what i started!
Old Mar 20, 2008 | 12:18 AM
neonracer1010's Avatar
neonracer1010
Default look what i started!
well i got bored and couldnt do any work on my car so i started to take all the roughness off the outside surface of the intake manifold.
its alot of work and a mess.
not sure if ill finish it or not. pictures dont really give it justice but u can kinda see what im doin
Old Mar 20, 2008 | 02:11 AM
12 volt's Avatar
12 volt
Default RE: look what i started!
you should port&polish the inside too.
have you seen this site?
http://www.angelfire.com/space/neon/porting.html
Old Mar 20, 2008 | 06:57 AM
mmench's Avatar
mmench
that **** takes hours and hours and hours to port the inside. of course i made a spacer and had to trim it up at the same time wich was the hard part. rite now im polishing the entire outside wich is even more of a pain on the runner part of the manifold. if you do the whole thing a dremel tool and a die grinder will be on your list of tools that you have used way to much and wouldnt care if you ever touched again
Old Mar 20, 2008 | 10:36 AM
spudsterier's Avatar
spudsterier
i love porting out the intakes....i spent alot of time on the one thats in my car now....and if i remember correctly, mmench, you have the bottom of one of them...
Old Mar 20, 2008 | 12:53 PM
boxerjl2's Avatar
boxerjl2
ok since this is about intake manifolds i have seen a spacer that goes on the manifold between the two parts of the manifold .. i think i heard somethign about a Plenum spacer,, can you use this spacer and a TB spacer??
i dont quite remember the spacer or the point im sure it was some Peformance
Old Mar 20, 2008 | 02:06 PM
12 volt's Avatar
12 volt
yes.
Old Mar 20, 2008 | 07:28 PM
neonracer1010
so i decided that i dont have enough time to finish it. so im prolly just gonnna get a new intake manifold and do it to that one.
Old Mar 20, 2008 | 08:13 PM
bone33's Avatar
bone33
while you are at it, you should try and make the pictures a little bigger. i cant see all the detail. [8D]
Old Mar 20, 2008 | 11:55 PM
neonracer1010
bone why do u hafta be such a dick about it[:@][:@][:@]
the pictures are just fine ur the only one that ever complains about it.
Old Mar 21, 2008 | 08:46 PM
bone33's Avatar
bone33
ORIGINAL: neonracer1010
damn dude settle down. i put a friggin [8D]to show my sarcasm..... so eat my shorts.
