2.4L motor fix
Old Mar 27, 2008 | 06:09 PM
mulletman11's Avatar
mulletman11
Default 2.4L motor fix
ok me and my buddy from down the road bought this car
99 2 door black rt w/ 2.4L motor swap
it was for sale on the other forum, $300.
it has a flawless wings west body kit
a set of 15" motegi rims & a set of 15" american racing rims
sts, aftermarket wing(gay)
that obserd paint job
an aftermarket tach & air/fuel gague
we went halves, so its not much money for me to lose
will will part out what we dont want, so if you have reqests pm me
the thing has a 2.4L DOHC motor from a 2000 stratus w less than 20k on the motor
it had upgraded bolt ons and upgraded internals, no boreing or porting thought
BUT
the motor doesnt run, hasent since 2004, and the guy just wants to get rid of it
me and jared want to rebuild the motor.
modern has a complete rebuild kit for a 2.4, but it looks lke it only includes block not head components
want some input as to what should be done to it to rebuild it, it was once a low 14s n/a car
Old Mar 27, 2008 | 06:28 PM
95to96transplantneon's Avatar
Default RE: 2.4L motor fix
you need to find out whats wrong with it first...
does it get fuel, spark, compression??? bent valves... find out whats wrong... first... then let me know.. does it turn over??? does it crank... make any noise???
I wouldent rebuild it if it allready has built block... just find out first you may have a gem...
Old Mar 27, 2008 | 06:31 PM
mulletman11
quote from guy selling it:
" the last day of it's life played out like this. i was driving on the interstate, shifted to fourth from fifth, and the engine just died... no noises no sounds, NOTHING. haha... i still don't know what's wrong with it, cause i just towed it to my back yard, and left it there. bought myself a brandy new 2003 srt4 i did. i was sick of baby-ing her so i finally gave up and bought a new one. so there ya go... make your decision from there. "
he says he has no idea why is doesnat wok
i payed him and am going to pick it up tomorow morning
Old Mar 27, 2008 | 06:50 PM
dude this honestly sounds like an easy fix... I would start checking the electronics, grounds, see if your getting power to everything... the injectors... blah blah blah....
does it turn over...
you would have one hell of a runner there if you could figure it out...
Old Mar 27, 2008 | 06:59 PM
mulletman11
i have a guy i talked to about it
he sayd it sounds like he broke the timing belt downshifting and maybe bent a few valves
but wouldnt u p&p it?
or get overbored pistons?
how much power would a 2300lb neon have with a worked 2.4L in it?
Old Mar 27, 2008 | 07:05 PM
If the timing belt snapped he would have heard something go boom in a big way but I seem to remember the 2.4 being non-intaferance motor...
just check threw the inspeciton window...
depends on how "worked" it is... Jeff B, the maker of booger bushings, has a 2.4 NA that runs 12.3 qm's and that was on the crane 24's now he has 28's... lol
it all depends... also I've read of someone putting up to a 150 SHOT of nos to a stock 2.4 and had no problems running 12's on a 2.4 with crane 14's and the regular bolt ons...
Old Mar 27, 2008 | 07:09 PM
It honestly sounds like electronic... if it just died... I would check voltage at the coil pack middle wire to see if it has power check the fuel by taking the fuel line off the fuel rail and sticking it in a mtdew bottle and see if gas comes out when you try to start it...
check to see if the injectors are pulseing... just get a long screwdriver and put it to the injector while trying to start it and see if you hear a clicking noise... it will be a constant click...
Does it turn over... lol
Old Mar 28, 2008 | 12:48 AM
mulletman11
ill get it most likely tomorow if not next sunday
and ill let u know
i hope for easy/cheap fix
but, murphys law is not my best friend
Old Mar 28, 2008 | 12:53 AM
I promise you it will be fine... We can get you threw it and you know alot yourself... between us we can figure it out... it will be an awsome car for ya...
Old Mar 28, 2008 | 01:03 AM
mulletman11
ok thanx man, besides jared right next to me, you will be my go to gu,y and we will build this together
first engine build via internet
i just want it to run, and run fast, get it repainted
i was thinking kinda like they did the mopar viper
gunmetal grey w/ a blood red offset stripe
