MPx Rebuild Kits
I'm looking at producing more power from my wife's SOHC. It only has 72,000 miles on it, so it's not really in need of a rebuild, so to say. I've lookd at MPx's Rebuild kits and was wondering what kind of power I might be able to expect. This winter I plan on boosting it, and I figured that I'd need to replace stock insides before hand, so I don't blow it up. Any of ya'll used these kits? Can I piece them together cheaper?
if you piece the kit together it will be about the same price...but it all depends on what kind of parts you use, compared to the kit..
if you are gonna turbo the motor, then it would be best to use the lowest compression pistons, but in the mean time, the motor would be slow as hell..
I know 2 people that have bought the kits and loved them. You might be able to save a few dollars here and there by piecing it together yourself, but then how much time are you going to spend looking around on the web.
if you plan on turboing the motor AND using 10.5:1 compression, then i wouldnt reccomend using very much boost at all...though it isnt even reccomended to use that compression with a turbo
What's stock for a neon? 9 something? The new cam will help out a little bit at restoring lost power though, wont it?
Trending Topics
right now i'm runnin 8.6 (or 8.5) je pistons, with fully built motor, just waiting for time to put turbo in place, with #12 crane cam, and it's still slow as hell
it's decent past about 3500-4000, but even that's nothin real spectacular
