swap
Old Apr 8, 2008 | 06:45 PM
luis's Avatar
luis
Junior Member
Default swap
i heard an 03 sxt engine would swap right into the 1st gen sohc engine bay with out any modding.
is this true?
if not. can any 1 tell me wich engine would,without much modding.
looking for new enigine.[&o]
[X(]
Old Apr 8, 2008 | 07:46 PM
fsu182's Avatar
fsu182
Default RE: swap
lies.
lol.
you cant swap in second gen neon engine with modding the car pretty heavily. you can either put in another neon engine, or a 2.4 from a pre 01 stratus, caravan etc. the 2.4 will require more modding (motor mounts, some brackets, and a bit of electrical work)
ur best bet is to buy another neon engine if u dont want to change much
check the 2.0 SOHC to DOHC sticky if you want to know what mods that takes - as its the most simple swap other than replacing the motor with another w/e you have now.
Old Apr 8, 2008 | 08:20 PM
mulletman11's Avatar
mulletman11
Default RE: swap
isnt the sxt just a trim level
is the engine an upgrde?
i thought only the magnum engine in the r/ts and acrs were upgraded
even if you could, it wouldnt be worth it to put it in there
Old Apr 9, 2008 | 01:35 AM
fsu182's Avatar
fsu182
Default RE: swap
yeah, i actually had an 03 sxt in graphite metallic (dark grey) brand new as my first car.
handled pretty well on dry pavement, but was slow. sxt= 6 disk stereo, cd, auto trans, and some other things.getsthe touring suspension which is a little better than a base neons.mine was fully loaded. cruise, sunroof, fog lights. i totaled it doing 30 mph in a parking lot....
swirved to miss someone backing out of their spot, and hit the center of a gaurdrail in the rain. the car smashed all the way back to the transmission and cracked the housing
air bags didnt even deploy
grandparents lost their business cuz my grandpa got into gambling. a tempo and blazer fit between my first neon and the one i have now.
id take my first gen any day. even though it has a lot of miles
Old Apr 9, 2008 | 10:21 PM
das2123's Avatar
das2123
Default RE: swap
The 03 SXT is a SOHC engine just like the one you have. It doesn't just bolt right in, but is a very easy swap.
Old Apr 9, 2008 | 10:32 PM
mulletman11
Default RE: swap
but is ther any advantage to swapping it?
Old Apr 9, 2008 | 10:35 PM
das2123's Avatar
das2123
Default RE: swap
Probably find one with lower miles on it.
Old Apr 9, 2008 | 10:41 PM
mulletman11
Default RE: swap
true
Old Apr 9, 2008 | 11:59 PM
fsu182's Avatar
fsu182
Default RE: swap
i thought the starter and wiring was completely different on the 2nd gen cars? dont you have to change the gauges and everything?
Old Apr 10, 2008 | 08:16 AM
das2123's Avatar
das2123
Default RE: swap
Excuse my first post....you can use an 00-02 engine, not an 03+ because of the move to the NGC PCM. It is a different block as well.
