FOGLIGHTS
Old Apr 20, 2008 | 11:20 PM
chenzo's Avatar
chenzo
Default RE: FOGLIGHTS
well i did this today, cept i cheated. i didnt solder, i just used one of the splice things. and it works great. so something to think about if you arent comfortable with your soldering skills.
Old May 19, 2008 | 11:22 PM
marauder's Avatar
marauder
Hi guys.. I'am Adan...i'am from panama..i want use my foglights..whitout havig to turn on the headlights switch... i need a picture so I can be able to do this job.. i need a picture from the fog light harness..
Thanks...
Old May 20, 2008 | 02:01 AM
12 volt's Avatar
12 volt
ORIGINAL: marauder
Thanks...
hola Adan
didnt you read any of this post?
follow these instrutions
[ol][*]Pull out the fog light/rear defogger panel[*]Cut the violet with white tracer wire, leaving as much as possible attached to the connector for the fog light switch.[*]Tape and tie the free end of the violet with white where it comes out of the harness. You don't want this shorting on anything![*]Strip the free end of the violet with white wire that's still connected to the fog light switch connector.[*]Strip a small section of the white wire that comes from the rear defog switch. DO NOT cut this wire, strip a section to make a splice. This is the third wire from the top.[*]Connect the stripped end of the violet with white wire to the white wire. Wrap tightly and solder. Tape and tie to prevent shorts.[/ol]
i can get you a pic of the harness but its not going to help since i havent done this mod.
