Dodge neon lower end
Old Apr 26, 2008 | 09:02 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default Dodge neon lower end
So I changed my head gasket thinking that was bad. Nope. Still 15psi in #4. So I am in need of a rebuilt/lower mileage lower end. Is anyone willing to build one for me? I will pay them? and buy new parts . I am just about done. I have fixed this thing for the last time. If i have to rebuild the lower end I will just crush it. Otherwise if someone has a short block for sale in good condition hit me up.
Old Apr 26, 2008 | 10:06 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: Dodge neon lower end
well when you had the head off did you check the cyclinder walls? how did they look. maybe you have a bad seating valve in 4
Old Apr 26, 2008 | 10:48 PM
I_Ride_Neon
Pistons and piston walls seemed great! I took the head in and had it done. I told them to make sure the head was good. this sucks.
Old Apr 26, 2008 | 10:49 PM
I_Ride_Neon
After I use the head bolts and gasket I cant use them again can I?
Old Apr 26, 2008 | 11:27 PM
95to96transplantneon's Avatar
no you can not the bolts are tighted past there stretching point when there tightened.
and the mls headgasket melts a bit when you first install it, to seal the head to the block it only melts once
Old Apr 26, 2008 | 11:49 PM
I_Ride_Neon
Baa. What should I do? I am out of funds. I maybe have like $200.
Old Apr 27, 2008 | 12:49 AM
DOHCgarrett t3
well has to be rings then but course you know that by now. are you sure they machined the head right?
Old Apr 27, 2008 | 10:14 PM
I_Ride_Neon
Okay so I pulled it apart. First question. The bearings were all in great shape. I plan to get the crank cleaned up at the shop? Is that right? Okay what about the lip on the top of the cylinder walls. Do I need to remove that? Will the new pistons rings hit that from the dohc pistons and mess it all up? I plan to use the plastigauge. Any other tips while I am in there?
