CHANGED MY MIND! (damaged piston pics pg3)
Old May 6, 2008 | 09:54 PM
95to96transplantneon's Avatar
Default RE: bye neon. bye bye
just wear a pair of tight fitting sunglasses and turn your head so the shrapnal goes into the back of your head... lol
Old May 6, 2008 | 10:11 PM
fsu182's Avatar
fsu182
yeah - so im metally retarded. then maybe i can actually carry on a conversation with the civic owners in the area.
we should set up an east coast neon meet. there are alot! of neon owners from IL on these forums for some reason. neons0x events are too far to drive.
Old May 6, 2008 | 10:21 PM
whtdoesitmatter's Avatar
whtdoesitmatter
i knew theres a few owners in ny and nj on the 2nd gen side
Old May 6, 2008 | 10:57 PM
99 Neon's Avatar
99 Neon
^^ im in new york ^^
Old May 7, 2008 | 12:11 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
anyone in alaska lol
Old May 7, 2008 | 03:58 AM
N30N's Avatar
N30N
ORIGINAL: fsu182
yeah. last time it wouldnt freaking come off! i rented a puller just in case. if i cant get it ill bust it up good. nothing to lose. except for maybe a thumb and an eye. its worth it for a running neon.
LOL your a true rebel man
Old May 7, 2008 | 09:40 AM
spp's Avatar
spp
i live in new jersey
Old May 7, 2008 | 12:43 PM
fsu182's Avatar
fsu182
the pulley came off with the puller correctly. boo!
so far i have everything off but the head - im nervous. i did find a pool of oil laying in the bottom of my intake manifold. im assuming the rings went and pushed oil up into the combustion chamber or the head cracked..... i really wish it was just a head gasket. guess i wont know till i get the camshaft sprockets off - then the head.
ill update u guys after lunch - let ya know whats busted.
Old May 7, 2008 | 12:44 PM
fsu182's Avatar
fsu182
we should all meet at mopars in carlisle, pa in july.
Old May 7, 2008 | 01:06 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Glad to hear you stuck with it. My engine was smoking out the valve cover bad, low compression in #4. Seen moisture in oil so assumed it was the head gasket. Cylinder walls and pistons seem to be in great shape on it. $150 mistake. I hope it works out for you! I have a dohc head laying around if you need one.
Zachary
