Got some bad news...
Old May 8, 2008 | 02:05 AM
95to96transplantneon's Avatar
Default Got some bad news...
Well Jeff Ball's (maker of booger bushings) 12 second NA NYG car blew up last week week while at the track. Apperently threw a rod bolt and blew parts for about 150 - 200 feet. And from what it sounds like he's not going to be doing anything with it.
He said "that's been together for over 2 years. 300+ passes, around 35,000 street miles with various cams. it's always been a ticking time bomb about the rods holding up. today was unfortunately the day. bearings look nearly perfect other than being folded over where I found them laying on the ground. no one can correctly say it was oil-system related. also trashed my 1/2 size radiator, punched two holes in it."
He also went on to say " There won't be any upgrades. It's all done for at least a year, probably longer. It will get rolled off the trailer in the near future, cover thrown back on and then will have misc stuff piled on top of it indefinitely. I've dumped a LOT of money into it over the last 10 years. It's time to stop all that and find a cheaper hooby."
Heres a pic of what he was able to scrape off the track...
Old May 8, 2008 | 02:28 AM
boxerjl2's Avatar
boxerjl2
Default RE: Got some bad news...
dang that sucks about how much hp was he pushing ???
Old May 8, 2008 | 09:30 AM
12 volt's Avatar
12 volt
do eagle h beams come with ARP bolts?
kinda lookes like a spun bearing
Old May 8, 2008 | 11:38 AM
Ghost Neon 2's Avatar
Ghost Neon 2
ORIGINAL: boxerjl2
235whp 187tq Something to that effect on a n/a 2.4L with 4.12FD mtx
Old May 8, 2008 | 12:51 PM
186tq close enuf...
they do come with arp.
he however had the old version of the rod...
the newer version comes with a bigger stronger rod bolt...
and 12 volt you are right he said he couldent confirm if it was oiling related or not... he had a speical set-up in his oil pump witch rasise the psi of the pump... If i can remember striaght he added some sort of washer to the bleeder bolt so it flowed more or something dont quote me....
Old May 8, 2008 | 01:55 PM
Ghost Neon 2
Closer than I thought, considering.... Sucks it went down, but he is quite right. It would cost WAY too much to repair/replace that. Gas going up at this rate, it should be at $10 per gal I the next few years.
Old May 8, 2008 | 02:16 PM
he still has his legindary 2.0 sitting around too...
Old May 9, 2008 | 09:45 AM
Ghost Neon 2
ORIGINAL: 95to96transplantneon
What is so fancy about it? Len had the lengendary 2.0L, unless we are talking n/a.
Old May 9, 2008 | 10:42 AM
das2123's Avatar
das2123
So this post is about someone else's car?
Old May 9, 2008 | 11:28 AM
its about jeff ***** car... come on its a ledgindary neon...
