oh no....
Old Jun 12, 2008 | 04:45 PM
fsu182's Avatar
fsu182
Default oh no....
engine started today. didnt let it run long. clutch wont engage.... you push the pedal and it moves with resistance like its moving the fork but the clutch doesnt engage.. the cable itself its hooked up right. how did this happen?
Old Jun 12, 2008 | 05:26 PM
95to96transplantneon's Avatar
Default RE: oh no....
did you clean out the transmission case and transfer shaft and re-lube it with lithium grease???
Old Jun 12, 2008 | 06:05 PM
fsu182's Avatar
fsu182
yes. some grease came with my new clutch and i used that. i took the transmission to the car wash and sprayed it.
Old Jun 12, 2008 | 06:10 PM
fsu182's Avatar
fsu182
is the spring against the firwall supposed to be compressed when the cable is attached to the fork? cuz it is.
im really hoping its the cable and not the throw-out bearing or something.
Old Jun 12, 2008 | 07:10 PM
does the fork move and not the clutch??? And what clutch did you install...
Old Jun 12, 2008 | 10:01 PM
fsu182's Avatar
fsu182
ill have to have someone else pedal it and see. i think i left the throw-out bearing resting a head of the fork and not attached to it
Old Jun 12, 2008 | 10:05 PM
fsu182's Avatar
fsu182
LUK pt standard replacement
Old Jun 12, 2008 | 11:17 PM
fsu182's Avatar
fsu182
u have to clip the throw out bearing the fork/spoon thing other wise it wont work will it? cuz i dont think i did this. looks like the fork moves.
Old Jun 13, 2008 | 12:21 AM
yeah you have to clip the throwout bearing to the fork... its probally binding
Old Jun 13, 2008 | 10:46 AM
fsu182's Avatar
fsu182
im leaking oil around the crank sensor. i pulled it and put some permatex around it. hope that helps. guess ill pull the transmission out tomorrow[&:]
