Sohc power Vs dohc......
Old 06-16-2008, 12:29 AM
johnMZ24's Avatar
johnMZ24
johnMZ24 is offline
Default RE: Sohc power Vs dohc......
ooo and how bout if any one knows how much or where i can find an r/t tranny at... no one has any around where i live.... also how hard is it gunna be if i put the engine in from the top? i got a cherry picker ta help me out
Old 06-16-2008, 12:41 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Ghost Neon 2 is offline
I have an r/t mtx. Two to be exact. one is pending sale to a fellow in canada. You want the other?
Old 06-16-2008, 01:18 AM
johnMZ24's Avatar
johnMZ24
johnMZ24 is offline
how much
Old 06-16-2008, 04:20 AM
TOOSTUBBORN2FAIL's Avatar
TOOSTUBBORN2FAIL
TOOSTUBBORN2FAIL is offline
just curious, but i have both a 9.8:1 sohc and a tlev 9.3:1 and the power difference isnt that noticable, i believe it was only supposed to be 3 hp at the crank, so why should it be so different with a DOHC on a SOHC block when it gives the same CR
Old 06-16-2008, 11:13 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
the engine will be pretty easy to drop in....
Old 06-16-2008, 11:41 AM
johnMZ24's Avatar
johnMZ24
johnMZ24 is offline
ok cool i hope its easy ta get in there.... i know the dohc had alot of top end and i was able to go right up to 6500 no prob and it pulled like a SOB, but now i heard ppl sayin the sohc dont have that kick in the pants.....
Old 06-16-2008, 11:50 AM
Ghost Neon 2
The dohc head on a block with sohc pistons has a CR of 9.2:1, which is .4 lower than it should be. So each dohc piston raises the CR .1. The combustion chamber on the dohc head is larger that that of the sohc heads, this is why using the dohc pistons with an sohc head raises so compression to 10.3:1. And why is lowers the overall compression of a dohc head used with a 2.0L block with sohc pistons. It is my theory that the tlev sohc head has a larger combustion chamber lowering the CR.
Old 06-16-2008, 12:22 PM
johnMZ24's Avatar
johnMZ24
johnMZ24 is offline
hmmm.... well.... i guess il find out but since gas a 405 a gallon for reg i guess il stay with my sohc when i put it in, its just gunna have a header and high flow cat....
Old 06-16-2008, 02:04 PM
Ghost Neon 2
The sunoco on York road here has Premium for $4.09
Old 06-16-2008, 02:29 PM
johnMZ24's Avatar
johnMZ24
johnMZ24 is offline
lol bet ur happy haha 4 a gallon sucks *** and its all city driving which sucks even more lol
Quick Reply: Sohc power Vs dohc......
