Sohc power Vs dohc......
Old Jun 16, 2008 | 08:07 PM
  #31
Ghost Neon 2's Avatar
Ghost Neon 2
Default RE: Sohc power Vs dohc......
My race car will require 100 octane? What kind of car?
Old Jun 16, 2008 | 11:31 PM
  #32
TOOSTUBBORN2FAIL's Avatar
TOOSTUBBORN2FAIL
96 Dodge Neon SCCA EM SOLO car
2.0L DOHC Turbo, shooting for 300 ft-lbs of torque with 100 ft-lbs at 2500RPM (this has been done)to power the 275/35-15s im going to run
plus the turbo puts me into a class with a 1700 pound weight limit, compared to a NA setup that would put me in a class with a 1380 pound weight limit (not attainable in a neon)
Old Jun 17, 2008 | 12:07 AM
  #33
Ghost Neon 2
You could run that setup on 87, at least I can.
http://www.allpar.com/fix/holler/old-cars.html
Old Jun 25, 2008 | 07:00 PM
  #34
dodge_honda9195's Avatar
dodge_honda9195
can u put a 2.4 top end on a single? or should i swap the full 2.4 in my single
Old Jun 25, 2008 | 07:18 PM
  #35
95to96transplantneon's Avatar
2.4 and 2.0 heads are the exact same head...
Old Jun 26, 2008 | 12:15 AM
  #36
Ghost Neon 2
ORIGINAL: dodge_honda9195
Dohc top end is not compatible with a sohc head at all.
Old Jun 26, 2008 | 02:55 AM
  #37
JackMehoffer69's Avatar
JackMehoffer69
The 2.0 and 2.4 DOHC head is exactly the same the only thing different on a 2.4 is the block is taller and the rods are taller.
2.0 sohc and dohc blocks are the same casting number!
