Tail Light Trivia..
That would be really handy, I dont want to rip the steering comumn apart if its not the switch. But chances are hes right because when i flip my hazards in the buttons gotta be in a certian spot or it dont work. My biggest trouble is most of my tols were stolen and I can not find a screw driver to fit in that back hole on the bottom (I dont have tilt wheel..lol).
Well, After Trying two switches I can safely say the problem is not fixed (Whoo im 5 bucks richer! :P)
Any other ideas: Heres the symptoms again.
Vehicle 1999 Dodge Neon (Featureless). 2.0L 4 Cyl SOHC 5-Speed
* The Rear side Drivers tail lights will not flash with Hazards, Brakes or Turn signals .
* The bulb DOES come on when the head lights are on (running lights as it were)
* As far as I can tell the only bulbs that are out: Drivers side front marker, Rear 3rd Tail.
* The Other lights on the circut Work fine but blink at a high rate of speed including the indicator on the insturment panel.
I Have Done:
Replaced Fuses (15 amp and 10 amp)
Changed Switches on column.
New bulbs.
Red Text!: I do not know if this poses any extra insight, however my Fiance just reminded me of an oddity thats happened a few times that maybe has something to do with this issue or maybe not?
On occasion a couple of times, when i started my car, the blinkers did not work, the heater controls did not work, may have been other things but i couldnt tell (radio is hard wired to battery, no other features really in the car like ac and junk)
Maybe this is something that will spark an old memory
I Have Done:
New bulbs.
My first shot at being an electrician.
I ran a wire from my negative battery cable all the way to the back of the car, and probed the three ground wires next to the lights ( Seems like i have two on one side and one on the other (the one is on the side that works) For a minute one of them read off the wall (displayed a 1 than running up and down numbers) after a few more tests, they were all stable at around 03.5 to around 04.9. I read this is within specs for a ground wire but does any of this sound odd or otherwise wrong? I fail with electrics to if i sucked at trying this lemme know :P
