whats da benefit?
Old Jun 27, 2008 | 10:24 PM
3rd white's Avatar
3rd white
Default whats da benefit?
hey, i noticed just about every1 on here has swapped out their mtx tb for an atx 1. i was wonderin what the benefit is.
p.s. feel free to laugh at my expense. it takes a lot more than this to make me feel dumb.
Old Jun 27, 2008 | 11:30 PM
neoncrazy101's Avatar
neoncrazy101
Default RE: whats da benefit?
MTX: 49mm
ATX: 52mm
plus the ATX has a different spring so the throttle response is better.
Old Jun 27, 2008 | 11:53 PM
95to96transplantneon's Avatar
Size like said before...
Throttle response is only helped due to the spring... however you sorta have to re-learn how to drive it due to every time you go over a bump your foot is going to bounce off the gas pedle and jerk your car around...
you all know what im talking about...
Old Jun 28, 2008 | 12:07 AM
JackMehoffer69's Avatar
JackMehoffer69
ORIGINAL: 95to96transplantneon
I actually have never had that problem and my car came stock with the atx throttlebody cuz its an atx I've driven plenty of Cavaliers that have a stiffer pedal and they engage like ****.
Old Jun 28, 2008 | 08:49 AM
Ghost Neon 2's Avatar
Ghost Neon 2
The mtx tb is 46mm as mentioned, and has more material to narrow the opening ( and thus restrict air flow) just before the throttle plate. The atx tb is 52mm and a straight through design. There is no extra material just before the throttle plate, less air restriction leading to better mass air flow. Both tb's are the same design, but one flows more air than the other. With an mtx being more responsive, this mod is quite cheap and effective with an upgraded air intake.
Old Jun 28, 2008 | 08:36 PM
3rd white's Avatar
3rd white
ok thanx guys, that makes a lot of sense. now 4 another stupid question. i just got my hands on a tb from a 1st gen 2.4L for free. will it bolt up? it loox like it might but i don't wanna rip my car apart and then end up lookin foolish.
Old Jun 28, 2008 | 08:41 PM
boxerjl2's Avatar
boxerjl2
i believe they are the same just swap out the sensors... they apeared to be the same to me when i did my swap...
Old Jun 28, 2008 | 08:45 PM
3rd white's Avatar
3rd white
good stuff, da swap is goin down on tues or wed. i'll let u know.
Old Jun 28, 2008 | 08:56 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
swap out your sensors too,
Old Jun 28, 2008 | 09:32 PM
3rd white's Avatar
3rd white
went yard hoppin 2day n noticed lots of plastic intake mani's on sohc. wonderin if its worth da couple of bux to do da swap.
