porting question
Old Jul 2, 2008 | 07:06 PM
3rd white's Avatar
3rd white
Default porting question
just pulled a dohc aluminum intake mani and im gonna port it out. is there nething i need to be careful of while doing this? i dont wanna screw it up.
Old Jul 2, 2008 | 08:45 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default RE: porting question
Yea dont mess it up.
Old Jul 2, 2008 | 09:19 PM
mmench's Avatar
mmench
use the gaskets for the manifold to help you match the two halves up correctly. i ported my own manifold and its easy to get carried away and screw up something. if you go to my myspace ill hurry up and put some pics of wat all i did to mine. it takes tons of hours to port it out well and if you take your time its well worth it. i also made a plenum spacer for mine outa 9/16 thick alluminum plate.
overall just take it slow and make sure you match everything up for it to be good
http://www.myspace.com/rh140
its pretty easy to do... getting surface finish is the hardest part... i used a few tools from work and then dremel tooled it with sanding wheels. after that i hand sanded it and wet sanded everything till it was mirror shinny
Old Jul 2, 2008 | 09:40 PM
95to96transplantneon's Avatar
and to be honest... you dont even need to get it mirror shiny if you just jet it down to like 120 grit its a drastic improvement...
Old Jul 2, 2008 | 09:44 PM
mmench's Avatar
mmench
true.... but im a machinist and to me i like the best finish i can get lol... anything better than hack saw finish is better than stock. i added some pics.. or atleast wat i could find on my cell phone since my camera is at home an hour away.....at work rite now
Old Jul 3, 2008 | 10:01 AM
3rd white's Avatar
3rd white
ok, well one of the reasons i ask is because i noticed that the injectors have their own little portal at the top of the mani near the outlet. while im porting do i want to make that area just as smooth or do i wanna stay clear of that n worry bout everything else.
Old Jul 3, 2008 | 10:13 AM
3rd white's Avatar
3rd white
p.s. i dont have a myspace so i cant look at urs. pm me da pics, or if dat wont work pm me for my email.
Old Jul 3, 2008 | 04:34 PM
mmench's Avatar
mmench
ill work on it. i made the injector hump smooth and trimed it down alot. just make sure you dont break through any of the walls
Old Jul 4, 2008 | 11:29 AM
Ghost Neon 2's Avatar
Ghost Neon 2
ORIGINAL: 3rd white
Aforementioned pics:
