srt-4 build help please
Old Jul 3, 2008 | 02:52 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default srt-4 build help please
Well I am building the 2.4 with srt-4 pistons and rods. I have the srt-4 turbo. If I use the stage 2 wastegate how much psi will that be? Do I need to use the stage 2 injectors with it? Or what should I use for injectors? And would it be wise to get the bearings for a srt-4 or just the stratus 2.4? Then for fuel should I just use the walboro with the srt-4 fmu? Thanks!
Old Jul 3, 2008 | 04:30 PM
95to96transplantneon's Avatar
Default RE: srt-4 build help please
stage 2 is like 14psi or somehweres around there...
Are you doing a full srt swap or a stratus block with srt internalls???
Then I will answer the rest...
Old Jul 3, 2008 | 04:32 PM
I_Ride_Neon
stratus 2.4 with srt-internals. WHats the best choice for the tensioner?
Old Jul 3, 2008 | 05:31 PM
srt-4 tentioner..
Timing Belt tensioner 4781570AB $74.28
and these are the internalls you MUST run...
Rod and piston assembled with pin 4884247AD (you need 4) 78.33 each 313.32 total
Rings 5093441AA 27.82 total Set is for all four pistons.
Main bearings 5012582AA 7.98 Total
Rod Bearings 5093448AB (you need 4) 6.08 each 24.32 total
TOTAL COST OF REBUILD 373.44 THAT’S RIGHT YOU CAN HAVE A BUILT BLOCK THAT WILL HANDLE 500HP FOR LESS THEN 400 BUCKS.
Old Jul 3, 2008 | 06:08 PM
I_Ride_Neon
WHy did you say MUST? I already bought srt-4 rods, pistons, rings, and pins. Are there different part numbers? Or are they all the same?
Old Jul 3, 2008 | 07:18 PM
your good...
What im saying is that you need all the bearings from the srt... not the stratus... the srt have a second oil hole allowing better oiling for the turbo applilcation... stratus only has one oiling hole on the bottom bearing... and I belive the srt bearings are tri metal bearings.
So this is what you need...
Old Jul 3, 2008 | 07:58 PM
I_Ride_Neon
Woot thanks!!!
Old Jul 4, 2008 | 08:02 AM
mulletman11's Avatar
mulletman11
zny benifit fomr installing an il catch can in a high compression non boosted car?
Old Jul 4, 2008 | 10:20 AM
spudsterier's Avatar
spudsterier
ORIGINAL: mulletman11
not really
a stock motor makes vaccum pressure...so does a high compression motor...
a turbo car makes boost...opposite of vaccum....
vaccum sucks, boost blows...basically....therefore you need a catch can to catch the oil that gets blown out of the motor
Old Jul 4, 2008 | 01:56 PM
mulletman11
i see
