any 1 know y?
Old 08-31-2008, 09:42 PM
streetracer88's Avatar
streetracer88
streetracer88 is offline
Default any 1 know y?
when i shut my car off the coolant bubbles and i just replaced the thermostat and water pump and it still boils any1 no why it does this?when i change my thermostat everything was fine i ran water threw the entire system till a steady stream came out so its not clogged. is this maybe a sign of the radiator going bad?any help is greatly appreciated thanks
Old 08-31-2008, 09:46 PM
neonracer1010's Avatar
neonracer1010
neonracer1010 is offline
could be a bad head gasket as wellll
Old 08-31-2008, 09:51 PM
streetracer88
it only has 66k on it do headgaskets usually go out at 66k on neons?i havent beat on it and old people owned it before me
Old 08-31-2008, 10:00 PM
I_Ride_Neon's Avatar
I_Ride_Neon
I_Ride_Neon is offline
What year is it? What mix is your coolant and is the coolant any good? No coolant leaks?
Old 08-31-2008, 10:03 PM
streetracer88
no coolant leaks its a 95' plymouth neon sohc and it only has 66k on it prestone 50/50 where you dont have to add anything and i just had the timing belt replaced on it and he put brand new coolant in it
I_Ride_Neon
So its a 95? If the head gasket has never been done then you may have an issue. I would change it now even if its not leaking. I see them go out 60k-80k Sometimes they last longer but its not worth the risk. 70k is a good time for timing belt change anyways.
^^ nvm on the timing belt I see you changed it.
Old 08-31-2008, 10:05 PM
streetracer88
i just had all the belts replaced because the old people parked it and let it sit for a couple months when i bought it and they said they parked it because they bought a brand new suv and didnt need the car anymore how much does it cost to get a headgasket replaced all said and done?
Old 08-31-2008, 10:06 PM
streetracer88
i also replaced all the spark plugs and wires and coil pack,starter,battery, valvecover gasket and both o2 sensors and i was planing on replacing the egr valve because it is malfunctioning
Old 08-31-2008, 10:07 PM
I_Ride_Neon
I can do it for under $80. But for a shop maybe like 300 or 400? New coolant and oil also. Shop will milk you. If you leave near Iowa I can have it done for $80 complete at my school. Who did your timing belt? I would of had the gasket done at that time.
Old 08-31-2008, 10:09 PM
streetracer88
i had a well known shop called glenns garage do it,i live in ny so i wish i lived near you so you could replace it lol...if thats the reason y its bubbling
