Ebay should have an adapter to convert T3 to the round TD05. Spud has a point, which TD05 do you have? 12a 14b 16,18,20G? Did it come off a Starion or an Eclipse?
Yeah, lookup t3 16g adapter on ebay, then you can use a standard t3 manifold. there are plenty of cast logs and tubular manifolds for the DOHC, not so for the SOHC.
Then you'd need a hahnracecraft manifold. I believe they use 16G's for their turbo kits. The website is www.turbosystem.com it is quite expensive however
