sparkplug?
Old Nov 19, 2008 | 08:42 PM
ohioguru's Avatar
ohioguru
Default sparkplug?
was changing my plugs and oil and someother stuff in my 96 sohc before winter and i noticed one of my plugs had enough oil ontop of it to coat my socket wrench. it does not burn oil. what needs done or fixed? and is this what happens before it starts burning oil? if a plug got loose could that have caused it cuz my one plug got loose a few weeks ago and was ticking.
Old Nov 19, 2008 | 09:36 PM
Nates_expresso's Avatar
Nates_expresso
Valve cover, gasket and or spark plug tubes said Fu and died. Easy to get the new gasket at a parts store. Spark plug tubes and VC might be a junkyard thing
~Nate
Old Nov 19, 2008 | 11:25 PM
spudsterier's Avatar
spudsterier
its just a spark plug tube seal.....new ones are included with a new valve cover gasket
Old Nov 20, 2008 | 11:51 AM
ohioguru's Avatar
ohioguru
these easy to change? ive never done it before
Old Nov 20, 2008 | 02:24 PM
12 volt's Avatar
12 volt
i would give it a 3 on the hard list.
http://www.autozone.com/shopping/rep...00c152800790c3
Old Nov 21, 2008 | 09:47 AM
das2123's Avatar
das2123
[url]http://www.autozone.com/shopping
I hope thats a 3 out of 10!?!?!
It's real simple to do and takes about 15 minutes tops.
Old Nov 21, 2008 | 04:15 PM
12 volt's Avatar
12 volt
yeah 3 only because you should use a trorque wrench and most people dont have one.
Old Nov 22, 2008 | 12:14 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
A torque wrench is a must in any garage, and so is a Blue Point puller.
Old Nov 22, 2008 | 09:55 AM
spudsterier
i have never torqued the valve cover bolts to specs...though i do have a torque wrench
and my poor mighty puller finally broke....waiting for snap on to get me a new one
Old Nov 22, 2008 | 02:00 PM
12 volt's Avatar
12 volt
what about the sparkplugs
