Flowmasters on neon?
Old 11-29-2008, 10:00 PM
Nates_expresso's Avatar
Nates_expresso
Nates_expresso is offline
Ok then, I'd use a DOHC muffeler for more UDP or ATX-TB moneys... Everything I've been reading says if you're DOHC to leave the muffler alone for a while because it flows pretty well stock. I dont know what a junkyard muffler goes for by you, but they're like $10 by me... $50 installation would be a bit high IMHO if you supply the muffler with enough piping attached so they only need to cut to fit... But I've never had it done before. They may need to add some hangers, so whatever they're asking is justified. It's a simple DIY if you know someone with a welder...
~Nate
Old 11-30-2008, 09:57 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
if you dont care about wanting a different tone, then the dohc muff will work fine
Old 12-01-2008, 12:22 PM
GLXRustang's Avatar
GLXRustang
GLXRustang is offline
Depending on when you need it, I'd give you mine for free, just pay shipping. Bolts right up. I need more growl, though. My manifold has a crack in it, and I hear that more than I hear the muffler!
Old 12-03-2008, 05:24 AM
oobical's Avatar
oobical
oobical is offline
I am not sure where south lebanon is from Dayton, but if you are close to where I am at I can lend a hand, there is a muffler guy I go to that did most of my exhausts for 20 bucks, that is to put it on and weld it. flowmaster will give you a loss in mpg, but not enough to matter but will give you a noticable throttle response over stock because of the flow, I was considering upgrading to a straight resonator and an unresonated exhaust tip due to affordability over sound.
Old 12-27-2008, 05:16 PM
bleger12's Avatar
bleger12
bleger12 is offline
I instlled a Bosal muffler on mine and it sounds great! Notsure about a Flowmaster, but mine has a 4 1/2 tip and sounds beefy! Exhaust upgrades are a must have on any Neon!
Old 12-29-2008, 03:55 PM
monkeyboywynn's Avatar
monkeyboywynn
monkeyboywynn is offline
I bought a DOHC muffler for my 98 SOHC for 10 bucks from a slavage yard. Merely required some WD40, a 15MM socket and brute force to replace in the driveway. Took about 30 mins. I really didn't notice any difference in sound or performance. Certainly not a deep growl. I checked out some examples on You Tube and bought a DYNOMAX cat back for 180. It's 2.5" piping as opposed to the stock 2.25" and sounds great on a few cars on You Tube. Should be a direct bolt on with 1 weld at the CAT. Will be deliverde this week.
Quick Reply: Flowmasters on neon?
