Flowmasters on neon?
Old 11-28-2008, 01:43 PM
ajpranger's Avatar
ajpranger
ajpranger is offline
Default Flowmasters on neon?
Has anyone ever put flowmasters on a neon, how well did it turn out. what are the advantages over stock. i need to replace my muffler on my 95 sohc neon and stock will cost me 120 installed and flowmaster will cost me 150 installed. I know that stock would probably be quieter but flowmasters should get more power and probably better mpg. is that correct? if i go with the flowmasters, if i go with the flowmasters there is no advantage of going with the dual exhaust as far as performace wise just looks correct, so for 80 dollars more it is worthless, correct. what about dohc exhaust is that better than flowmaster or is that same performance-wise.
Old 11-28-2008, 09:14 PM
Slo_neon_90's Avatar
Slo_neon_90
Slo_neon_90 is offline
uhhhh when you open up the exhaust to a certain amount it will help your car yes mpg wise i dunno but you gain like 3 or 5 h.p which in terms could help your mpg so there is tht answer will if be that much greater.... No is it worth it when it's only 30-80 bucks more ..... if you like the sound yeah
Old 11-28-2008, 09:24 PM
streetracer88's Avatar
streetracer88
streetracer88 is offline
Flowmaster is better sounds sick and def. a gain i dont know much about the mpg or dohc
Old 11-28-2008, 09:36 PM
Slo_neon_90
^+1 just don't overdue it with the muffler or the tip
you don't want it to sound like a civic with a fartcan on the back
Old 11-28-2008, 11:12 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
i had a 40 series flow master on my old r/t for a while...kinda loud, but sounded mean as hell
Old 11-29-2008, 08:41 AM
ajpranger's Avatar
ajpranger
right now my baffle has broken loose my muffler is still in tact but sound like a straight pipe. would flowmasters be quieter than that?
Old 11-29-2008, 01:35 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
DOHCgarrett t3 is offline
I have a Flowmaster on my car (I am not sure what series) it sounds loud but not rice loud.
Old 11-29-2008, 02:32 PM
spudsterier
if you absolutely want to go flowmaster, then i would reccomend a 50 series.....little bit quieter
Old 11-29-2008, 08:49 PM
Nates_expresso's Avatar
Nates_expresso
Nates_expresso is offline
I've read that the DOHC muffeler flows alot better. Why not just pull one of them from a junkyard and save some beer money?
~Nate
Old 11-29-2008, 09:43 PM
ajpranger's Avatar
ajpranger
cuz i dont drink. that is what i was asking what would be better. flows or dohc muffler
Quick Reply: Flowmasters on neon?
