does any one now?
Old 01-15-2009, 03:59 PM
I_Ride_Neon's Avatar
I_Ride_Neon
I_Ride_Neon is offline
I have Swapped a neon motor into a eclipse before. I just want to say that the only thing that is the same is the block, pistons, crank, bed plate, oil pump, water pump. THe eclipse motor also follows the neon when the changed between 95 and 96. So yes you can use a eclipse lower end in a neon. But thats it. There is so much for to the eclipse under the hood, it really sucks switching everything from the old motor to the new.
Old 01-16-2009, 05:30 PM
slo_neonRT's Avatar
slo_neonRT
slo_neonRT is offline
well my mopar acr book says that my acr neon has a 420a motor in it.....maybe i read wut u said wrong but i think ur saying that the neon dont have a 420a motor and every neon booke i have from performance to just a regular booke u buy from a part store says it has a 420a motor.....but u might be right i dont no every thing
Old 01-16-2009, 10:37 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
no you read it properly....neons dont have a 420a...
if you want to get technical, the blocks would be the same, but, the engine consists of more then just the block and since everything above the block is different, it isnt a 420a engine...
Old 01-17-2009, 08:08 PM
das2123's Avatar
das2123
das2123 is offline
Please scan or take a picture of that for me please.
