Crank case oil leak
Old 02-05-2009 | 02:39 AM
12 volt's Avatar
12 volt
Nope thats the only way to fix it correctly
Old 02-05-2009 | 05:18 PM
sabin420's Avatar
sabin420
that's what I think too...Just hoping for an easy way out.
Old 02-05-2009 | 11:14 PM
streetracer88's Avatar
streetracer88
lol thats never the case lol...
Old 02-05-2009 | 11:24 PM
sabin420's Avatar
sabin420
well, being as I've gone through 5 motors and 2 trannys in my neon, I've customized the setup of it to come out very fast...that and for when I'm at the track. I've customized tools to pull just the tranny by myself...a hydrolic lift that's customized to perfectly cradle and bolt up the tranny. Modified the motor mounts so I can reach bolts easier and faster, put the battery in the passenger's compartment (Required for any competition Road Racing), Set up the whole engine bay to come apart quickly...but then again, there isn't that much on that car to make any simpler than it already is.
Old 02-05-2009 | 11:26 PM
streetracer88
yah i hear ya thats cool how you made it easier alot more convient
Old 02-05-2009 | 11:30 PM
sabin420's Avatar
sabin420
when I can, I'll get pics of my creations and put them on here...I got a whole machine shop at work where I can do whatever I want...as long as it's not on my shift.
Old 02-06-2009 | 12:51 AM
das2123's Avatar
das2123
Originally Posted by sabin420
it is a steady squirt whille the motor is running and sprays right onto my 1st cylinder headder pipe (Pacesetter Long Tube Headders)
Pacesetter doesn't make a long tube header for the neon.
You sure it isn't the oil pressure sender? Just a thought.
Old 02-07-2009 | 07:00 AM
sabin420's Avatar
sabin420
das...i'm 100% sure what it is.
Quick Reply: Crank case oil leak
