Crank case oil leak
Old Feb 1, 2009 | 02:49 PM
sabin420's Avatar
sabin420
Default Crank case oil leak
I have an oil leak right above the oil filter where the crank case meets the block. I was wondering if you can take the crank case off without taking the motor out of the car. I know I will have to retorque the crank bolts and take off the oil pickup.
Old Feb 1, 2009 | 11:12 PM
sabin420's Avatar
sabin420
oh yeah, this is a new Re-Manufactured Engine...Warranty already expired
Old Feb 2, 2009 | 05:11 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
are you sure it is not the head gasket? 100%
Old Feb 2, 2009 | 07:04 PM
sabin420's Avatar
sabin420
100% positive...the crank case is the complete lower section of the block that holds the crank in the engine block...It houses the Main Bearings and is one piece.
Old Feb 2, 2009 | 07:07 PM
sabin420's Avatar
sabin420
it is a steady squirt whille the motor is running and sprays right onto my 1st cylinder headder pipe (Pacesetter Long Tube Headders)
Old Feb 3, 2009 | 04:51 PM
sabin420's Avatar
sabin420
if anyone can tell me an answer b4 i get to cleaning out my garage to pull the engine once more...when It warms up a little
Old Feb 3, 2009 | 06:44 PM
DOHCgarrett t3
Mighty Putty and new Mighty Mendit.
Old Feb 3, 2009 | 09:23 PM
sabin420's Avatar
sabin420
I'm not puttin that stuff on my engine...might fall off on the race track.
Old Feb 4, 2009 | 02:57 AM
12 volt's Avatar
12 volt
kinda sounds like you bedplate is leaking oil. Youll need a anaerobic sealer (http://www.permatex.com/products/aut...ket_makers.htm) becarefull not to use too much as you dont want it going inside the crank case or opening the tolerances on the crank bearings.
fig 23.21 should have the sealant going around the oil filter holes
Old Feb 4, 2009 | 04:33 PM
sabin420's Avatar
sabin420
yes, i know that already...all i was wondering is if there was a way to do this without taking the engine out of the car and spitting it from the tranny...I'm tired of doing that...done had this engine in and out so many times, it'll take me less than 30 min, and I'm kinda lazy after getting home from work every day fixing machines at the paint factory I work at. Looking for the easier way out.
