i did all my ground work this year for me to turbo it next year after i break it in. i did find a kit on ebay that has just about every thing even a new fuel pump and a turbo timer,tach, piping, iner cooler, the whole works fpr $999 its the best kit so far,but i am looking for a mopar performance computer for 98 sohc highline with mt new/or used if it works good?
Ya might want to do a little more research then. The Mopar performance PCM advances the timing and that does not go well with boost.
I thought it was programmable I must have read it wrong so what ecu or ecu is available for the turbo setups? I have already removed the egr and a/c so my check engine light is on so I need to get rid of that for emissions to pass
No PCM/ECU is programmable for the neon. You can either run the stock PCM or use a stand alone EMS.
do you know what resistor it would be so i can pick it up from the radio shack also i was told that the stock ecu wont read the boost so i guess better question is how can i make the stock one work and what about retarding the timing. not formiliar with an ems
the resistor is a 1.2k ohm 10watt not avail. at radio shack will have to order it from ebay. but just for future refeance. so will an ems get rid of the speed limiter also?
