Cat cloged?
Old Feb 27, 2009 | 03:34 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Exclamation Cat cloged?
Well, I think the cat is clogged as the title says. I am not sure what symptoms I should be looking for to determine if the cat is cloged or not.
95 plymouth SOHC
Symptoms include:
1. rough below idle rpm's (not sure no tac)
2. exhaust leak sound that gets louder as you near the exhaust outlet behind the car.
3. codes 12 & 13 map sensor voltage to low and or vacuume leak
4. glowing red near the cats inlet and outlet.
I have checked up and down for vacuume leaks and have found none. replaced the MAP sensor with a JY-sensor.
what else should I look for?
Old Feb 27, 2009 | 05:30 PM
Nates_expresso's Avatar
Nates_expresso
The glowing red is a dead give away...
Replace it with a cheap universal high flow one, and you'll be set.
~Nate
Old Feb 28, 2009 | 10:59 PM
streetracer88's Avatar
streetracer88
im with nate the cat is def. clogged if its glowing thats always the case usually.....good luck
Old Feb 28, 2009 | 11:56 PM
DOHCgarrett t3
well fixed the cat still runs like dog ****. I am going to try and replace the EGR valve gasket. I think i have a vacuume leak there. If I do the EGR block off with A coin, do I still use the gasket?
Old Mar 1, 2009 | 12:12 AM
streetracer88
it would prolly be a good idea to seal it you dont have emissions where you live?
Old Mar 1, 2009 | 01:45 PM
DOHCgarrett t3
not here im Michigan there is no Emissions testing. Back in Anchorage there was testing done. or you get a red sticker and you can't drive with that sticker between the months of september - march.
Old Mar 1, 2009 | 07:22 PM
streetracer88
o0o k did you try putting the gasket on with the quarter?
Old Mar 1, 2009 | 09:47 PM
DOHCgarrett t3
no i have not messed with any of it yet. I have yet to get the gasket and try.
Old Mar 2, 2009 | 02:57 PM
DOHCgarrett t3
This isn't DOHCGarrett, but I am helping him work on the car.
I am going to head over there in a few minutes here and put the gasket on with the quarter thing, but I'm not sure exactly how to do it. If any of you are around can you post me a link on what exactly I am doing with the quarter? I suppose I am sticking the quarter in the hole and putting the EGR back over it? So it's blocked off.
Also, any other ideas? The car won't reach over 10MPH roughly either...maybe 15 downhill...
We have to floor it from a long distance to even get it up the driveway, and even then sometimes it will need Fred Flintstones assistance.
I'll be around refreshing for a few, and would appreciate any help.
Thanks.
