Synthetic gear lubricant for manual trans?
Old Mar 9, 2005 | 03:27 AM
builtfourspeed's Avatar
builtfourspeed
Default Synthetic gear lubricant for manual trans?
Does anyone know if switching over to a synthetic gear lubricant for the manual in my 95 SOHC would be an issue? I have traditionally done this with my other cars with good results but I am unfamiliar with domestic manuals, i.e. what is the stock fluid weight etc... Any input is always appreciated.
-Cheers
Old Mar 11, 2005 | 11:31 PM
NYG's Avatar
NYG
Default RE: Synthetic gear lubricant for manual trans?
Funny you ask - I was going to visit my local Dodge dealer to ask that same question - will let you know what I find out this weekend!
Greg
Old Mar 12, 2005 | 02:52 PM
builtfourspeed
Dont trust the dealer...Look away...
Oh well, let me know what those rackateers have to say anyway, probably something along the lines of ----"The OEM fluid in your tranmission has special chemicals and properties (bullsh*t) that allow it to function better (bullsh*t) than it would with aftermarket synthetic fluid (bullsh*t) and it only costs five times as much at our parts counter..."---
Fight the power!...but let me know what they say-
Thanx
Old Mar 12, 2005 | 03:01 PM
casper's Avatar
casper
I can't see why not. Just make sure you get the right kind.
Old Mar 12, 2005 | 07:35 PM
NYG's Avatar
NYG
My Local Dodge Dealership is wanting to call Mopar on Monday and get there suggestion. My local dealership knows I race my Neon and rather ask Mopar for suggestions then to give me a cookie cutter response that my not meet my needs!
Let you know what I find out on Monday.
Greg
Old Mar 13, 2005 | 02:36 PM
NYG's Avatar
NYG
My Local Dealer is not like your typical dealer - They are going to contact Mopar Monday and ask them what is being run in there race cars and why - My Dealer know I race - the guys in the shop said they have seen everything from Amsoil to Purple stuff - they said the Amsoil is not bad - the techs suggest not to use the Delo in the auto's they had one that came in all gunked (SP?) up.
Greg
Old Mar 15, 2005 | 08:31 AM
RadarLove's Avatar
RadarLove
The factory service manual says to use the Mopar Transaxle Lubricant. It also says in bold letters to never use ATF.
The dealership will tell you to use ATF (by their chart) in the NVT-350. But they will tell you to use the Mopar fluid in the exact same tranny on the PT cruiser. Odd...
I stick with the Mopar fluid and have never had problems. How often do you change your tranny fluid anyways? I've done it twice in 235,000 miles - both for clutch replacements.
Best of luck!
Old Mar 15, 2005 | 07:40 PM
builtfourspeed
It isnt an issue of neccesity, I did so previously at the suggestion of an older racer on my Honda and my Toyota MR2 5spd.'s. In both cases there was a very noticable increase in transmission performance, just want to make sure it would not be an issue in the Neon.
-Cheers
Old Mar 16, 2005 | 02:51 AM
casper's Avatar
casper
ORIGINAL: RadarLove
Best of luck!
My 98 neon calls for atf+4, thats what the owners manual says. I just change the clutch and replaced the fluid about 2 months ago and thats what I used and it is fine.
Old Mar 16, 2005 | 11:17 AM
chud298's Avatar
chud298
ORIGINAL: casper
would that go for the 98 R/T too?
