indy inatke manifold
Old May 7, 2009 | 10:25 PM
99sohcslammer's Avatar
99sohcslammer
Default indy inatke manifold
ok everyone im new to dodge and im looking for input..i have a 13.0 neon with alota mods i guess
solid motor mounts
msd with 2 step
3.55 trans with phantom lsd
light wieght fly wheel and stage 4 clutch
dohc block with 10.5:1 pistons
light wieght under driven pulley
fully built sohc head with crane 14 cam and full titanium valve train with max port & polish
kirk long tube header with full 2 1/2 exaust
aem cam gear
nx wet 75 ****
mopar chipped ecu
nitto auto X tires they apparently grab better then drag radials x=
and full gut out
its capeable of 12.8's with traction and not snapen axles
my question is back to the intake manifold im running a stock p.o.s one which i hear is the weak point and i hear the indy flows realy nice so is it worth me getting one with a 60 mm t.b or just buy and aftermarket? and why does everyone say its a pain in the *** to install? thanks jeremy
Old May 8, 2009 | 03:33 AM
Altima_wb's Avatar
Altima_wb
with those amount of mods you would deff stand to gain a fair amount of power my switching to the indy intake manifold and the 60mm tb... hell even with less mods then that you can get a pretty good increase from those two mods...
Old May 8, 2009 | 10:10 AM
99sohcslammer
thank you sir that was the answer i was looking for.so as far as them being a bitch to install can anyone throw me some info? ill also use search and see what i can find but info from others that have done it is appreciated. thanks jeremy
Old May 8, 2009 | 10:17 AM
das2123's Avatar
das2123
The install is a PITA. It isn't a plug and play fit. You will have to kick and muscle some things in there to get the alignment/fit good.
You should see a nice improvement with the Indy and the 60mm TB.
Old May 8, 2009 | 01:14 PM
GLXRustang's Avatar
GLXRustang
Ah yes finally a NO2 extremist! Not related to your post, but can you tell us how the NO2 works out for you? 13's is quick enough, but 12's in a neon without turbo is unheard of in the posts I've read here.
Old May 8, 2009 | 02:50 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Indy is easy to install if you pull the radiator and take your time. Otherwise yes, Kicking and jumping may be required. Its a very tight fit, and alot of the time it doesnt seem like its even made for the neon. Anyways. I had a sohc mild built with 10.5 ,light cam, mopar ecu, stripped and I went back to the stock manifold because I lost so much low-mid range. I heard people dynoed them on stock motors and actually lost whp with the indy. So I hope its worth it for your build.
Old May 8, 2009 | 11:58 PM
Captansavaho's Avatar
Captansavaho
there was a guy name All Motor Mike(AMM) he might still be around or on the 1st gen forum...he makes a great intake..unfortunately i do not know how to get ahold of him
Old May 9, 2009 | 10:15 AM
Altima_wb's Avatar
Altima_wb
I don't think the guy is a member here but i did watch a guy run a 12.8 without a turbo in a first gen sohc 5spd... with a 75 shot of N2o a #14 cam... ice man air intake, kirk header and some kinda exhaust... oh also and its kinda funny he was running an afx computer... lol well lets just say it was fast the first 2 times... third time she let go about half way down the track.... and this was after i spent a half hour trying to tell him to swap back to his stock ecu cause the afx has way to much timing for a 75 shot....
Old May 9, 2009 | 11:12 AM
99sohcslammer
yea mine should hit atleast 12'8s with some god dam traction! lol and i appreciate all the info.i have my slip for the 13.0 and im hopen to have one for 12's baby! and im going to invest in the indy i/m and 60 mm t/b so we'll see how it works out.im going to pull the rad to make it easier. thanks again for the info. anyone from around mass,ct,or nh i go to new england dragway so maybe one of you can see my 12 pass if it goes down lol
Old May 10, 2009 | 03:07 PM
sabin420's Avatar
sabin420
I wounder what mine would do at the strip seeing ya'll hitting 13's and high 12's on all motor. I got the #18 cam, 60mm throttle body, port-matched stock plastic intake manifold (it does do better all around than the INDY), 12.1:1 compression, the only thing i don't have is the LSD and the NOS. but I do also have the anti-friction coating on all my bearings and pistons.
