Gripping tires
Old 05-13-2009, 12:18 PM
I_Ride_Neon's Avatar
I_Ride_Neon
I_Ride_Neon is offline
Default Gripping tires
Well I got my turbo neon running tip top and as of now I cant use 1st gear in a race. It all tire spin. Usually second also spins until I bounce the limiter a few times. Then it stops spinning at about 55-60. I always granny shift 3rd so it doesnt spin because that could put me in the ditch. Anyways as you can see I am having lots of traction problems. I have good racing tires on 17"s. I am considering drag radials for a set of 15" alloys. But drag tires are new to me and I would like input. I have a centerforce clutch and stock cv's. I am going to the track next week and want to try for 13's.
Old 05-13-2009, 01:06 PM
Captansavaho's Avatar
Captansavaho
Captansavaho is offline
i have been in a cobra with mickey Thompson slicks and those gripped pretty well with 550 whp.. also Hoosier is a good brand
Old 05-13-2009, 03:19 PM
I_Ride_Neon
Yea but I would like to keep the car street legal so I can drive it to the track. I was thinking drag radials. But what modifications will I need to support the rubber and the size.
Old 05-13-2009, 03:42 PM
Captansavaho
mickey thompson does make a street legal slick..what size do you wanna go with?? any rims in mind ?
check this out http://www.mickeythompsontires.com/s...ETStreetRadial
it says the size is 235/60r/15's i would think your just gonna rub unless you were to get some sort of spacer
Old 05-13-2009, 05:23 PM
dtjackten's Avatar
dtjackten
dtjackten is offline
2nd gen neon peace keeper
i ride, first of all, if u go with a "street leagal" drag radial. remember u will be replacing them ALOT, they are a soft compound and will ware very very fast... i am talking like once a season fast depending on how much u drive the car....
next ur rim size, 17s r going to be hard with little side wall on them to get a good tire... honestly that is why i went with a bigger turbo in my car, little lag means just enough time to maybe catch some traction... if u go with drag radials get ready to replace them often....
Old 05-13-2009, 08:01 PM
I_Ride_Neon
Oh the rims I planned to use the radials are 15" alloys from the newer neons. I have lots of rims different sizes. Thats not an issue . I plan to drive with them to the track or to a race, then switch them off when I get back.
Old 05-13-2009, 10:02 PM
sabin420's Avatar
sabin420
sabin420 is offline
What tire pressure you got on your street tires? might just have to run lower psi. try 30psi. or even 25 if you have to go lower. I would try that before making the big expence on a set of drag radials.
Old 05-13-2009, 10:31 PM
berretta96's Avatar
berretta96
berretta96 is offline
tips I've learned since my turbo (low 200whp). Launch using the ebrake (loads the suspension and gets you close to boost, 0-2 PSI for me). If they break loose, back off a little (don't bounce it off the limiter LOL) then get back into it when they grip. I also noticed that "no lift shifts" made a big difference and rarely lost traction hitting gears.
I have 15" SXT wheels on my 1st gen. I'm gonna try 205/50/15 tires eventually. I had 18's on before and traction was HORRIBLE on those stiff bastards.
I'm shooting for 400 whp on my new build. I can't imagine street tires at that point. "ROLLING STARTS FTW"
Old 05-14-2009, 09:36 PM
99sohcslammer's Avatar
99sohcslammer
99sohcslammer is offline
im running nitto auto X tires and they grip amazing! ill get the exact name of them and there 14" but you can get them in 15" i launch at 5,000rpm and they grab like a beast but there $250ish each tire..oh and i run 22psi on them ive gone as low as 15 but only twice 22 is just sex
Quick Reply: Gripping tires
