Need a Experts Help. HELP!!
Okay heres the deal, I have this 1996 dodge Neon SOHC. I have a minor over heating problem ( i don't think its a head gasket ). Also it has a back firing problem. i changer the Fuel Filter, Air filter, oil change with a oil filter. I also changed the spark plugs. then its still ran rough. so i went to check the timing and the pulley attached to the hydrolic tensioner was bad so i changed the timing belt, tensioner, pulley, water pump. and line up all the timing marks and still runs bad but it don't back fire as much.
also the check engine lite was on and i hooked it up and it said i needed a cam sensor and a sensor for the temp. i have not put on the sensors because it got late.
do you think this is going to work?
Any Thing i could do?
Thanks guys all sensors where replaced and every thing seams fine with the running condition. the instrument panel is not working ( speedo, temp and gas ) to let you konw i just got the car 3 days befor this post and i did not notice these problems due to the fact i got it at the auction. Any help on the instrument panel? also its an automatic.
ok i replaced the thermostat and still over heated. so i took it out yesterday and did not drive it around because battery light is on and then i would not start. i went and got a new alternator. i will keep you posted and let you know if the car over heats
i have a good question i think.
I know that in older cars ( pre 74) if you have a bad alternator you can just take off the positave or negitave. how can i check?
also i just changed the alternator today and then still nothing. so i went to check the battery and on the way there the car just died. the guys at the parts department said that was normal. so i put my battery to charge, and after an hour they said the battery was bad. so the question is.
Do you think it could be just the battery, connection, or ???? just need help
Thanks for all the up dating i am getting you guys ROCK!
Trending Topics
i was figuring if the alternator was good, and the battery was bad, i would still have some power to opperate the winshield wipers, blinkers and fa.n. cause non of it came on.
Kinda, with some ecu's if there isnt much volts it would only control what is needed, but to answer your other post you disconnect the neg, if the car still runs then bad batt, if it dies then alt. I good batt will kinda build itself back, do you use a regular batt? If you have the money get a optima or odessey batt alot better, plus with these you wont get that crap growing on the terminals. Plus check all the wires from the battery, if the corrosion got into the wire then replace it, actually if you want to just replace the power and ground go up to a 2 gauge wire, the wires that come on stock have a bit of resistance, if you go bigger then no resistance. Also with the car running if you have a volt meter check the batt it should be around 14.0-14.5 volts maybe high 13s.
