Harmonic Balancer Puller & Crank Pulley Tool?
Old Mar 26, 2005 | 02:11 PM
NYG's Avatar
NYG
Default Harmonic Balancer Puller & Crank Pulley Tool?
Ok - Where can I get a Harmonic Balancer Puller for a 96 Dodge Neon DOHC?
I have tried all of the AutoParts store and the local Dodge Dealer as well as Mac Tools and Snap On Tools Web Sites!
No one seems to have this tool and I desperately needed it last night - I have missed my chance to go racing this weekend!
The Universal ones from the parts store won't fit - they are too big - can not use the Clamp style - it must have the 6mm bolts to attach to the front of the HB.
The Local Dodge Dealer wants over 100 Bucks for one New!
Greg
Old Mar 26, 2005 | 05:36 PM
NYG's Avatar
NYG
Default RE: Harmonic Balancer Puller Tool?
Actually the tool I am looking for is to pull the Timing Belt Pulley off the Crank!
I just got lucky and a dealer on the other side of town sold me one for just over 20 Bucks!
But I will still need to invest in a puller that will yank the Timing Belt Pulley off the Crank - any helpwould be appreciated
Greg
Old Mar 26, 2005 | 06:25 PM
RayDog26's Avatar
RayDog26
if snap-on or mac tools don't sell it....... then its prolly not made any where lol
any pulley puller should work wouldn't it ??
Old Mar 26, 2005 | 07:01 PM
NYG's Avatar
NYG
I have tried the universal Puller Kits from Harbor Freight, AutoZone, and Advance. all of those kits are for big block engines like V8's.
The bolt size for the Neon is an 8 metric and takes some really long screws! Plus the Universal kits will bend the screws out ward because the center block part of the tool is not narrow enough for the Neon Crank Pulley.
Not to mention the 3 trips to Home Depot to get screws for it because I kept snapping the bolts Heads off!
I left a voicemail for my local snap on guy - see if it is in the catalog since I could not find it on the web.
Any Help would be greatly appreciated!
Greg
Old Mar 26, 2005 | 11:56 PM
casper's Avatar
casper
I think your doin somethin wrong, the one from autozone worked fine for me.
Old Mar 27, 2005 | 07:38 AM
RadarLove's Avatar
RadarLove
Snap-On and Miller Special Tools both carry the correct part for the timing belt gear on the crank. For the accessory pully, a 3-jaw 5-ton gear puller is all you need, and readily available for purchase or rent from Autozone.
Best of luck!
Old Mar 28, 2005 | 01:06 AM
NYG's Avatar
NYG
Hi Casper - the one I got from the parts store and the one I got from Harbor Freight had the holes in all of the fingers ( fingers in lack of better terms) where spread out too far and the bolts that came with those kits were all way to big - I had to make several trips to Home Depot to pick up bolts and washers to make it fit - and of course snap a few bolts and bend a few washers.
Greg
Old Mar 28, 2005 | 01:12 AM
NYG's Avatar
NYG
Thanks Radarlove - Just the info I needed - did a google search on Miller Special tools and found Chrysler Crankshaft Pulley Puller/Installer SP92100 - Just what I needed - unfortunately it is not cheap! $63.99 - alot of mulla for something that will occasionally be used!
I am going to keep shopping and hope I can find one cheaper.
Greg
Old Apr 1, 2005 | 02:29 AM
SlowAssNeon's Avatar
SlowAssNeon
ORIGINAL: NYG
Greg
you should be able to rent the chrysler pulley puller from most parts stores, along with the correct insert.
i definately advise against trying to use universal pullers.. as youve found out they dont always work too well (sure, ive used em before and they worked, but ive also had them break more than work correctly as well)
