Hard Starting Neon
Old 09-21-2009, 03:11 PM
buckskin's Avatar
buckskin
buckskin is offline
Originally Posted by neisg1
An egr valve stuck open will cause hard starting as you discribed and no engine codes.
Yeah it doesnt throw any codes. Does the egr valve need replaced if it is stuck or can I take it off, clean it and put it back on?
Old 09-21-2009, 09:46 PM
neisg1's Avatar
neisg1
neisg1 is offline
It's worth a try they do tend to get carbon build up.
When My 95 did this I found a low mileage one at the wrecker. Sometimes if you tap the EGR it will temporarily loosen and will then start OK for a while.
Quick Reply: Hard Starting Neon
