fuel cutoff
Old Apr 2, 2005 | 04:04 AM
BDigital2000's Avatar
BDigital2000
Default fuel cutoff
Anyone know the fuel cutoff of a 96 sohc 2.0l 5 sp neon.. the rpm's???
trying to figure it out since my neon doesn't have a tach. going to install one soon when i make it to pitt to get the car
thanks guys
Brent
Old Apr 2, 2005 | 07:16 AM
casper's Avatar
casper
Default RE: fuel cutoff
It is about 6200-6500. depending on the car.
Old Apr 2, 2005 | 02:12 PM
BDigital2000
Thanks... now is that before or after redline on the cars?
Old Apr 2, 2005 | 02:51 PM
casper's Avatar
casper
Its after the peak in the fuel curve, but that is the redline.
Old Apr 2, 2005 | 07:15 PM
SlowAssNeon's Avatar
SlowAssNeon
ORIGINAL: casper
depending on the car? all 1g sohc's had the same rev limit and fuel cutoff:
Redline: 6500 rpm
Rev Limiter: 6750 rpm
http://neons.org/faq/faq/FAQ_ET.html#SOHC
remember that the redline is just where the "red line" starts on the tachometer.. while the rev limiter is where the fuel cutoff is at (which, limits the revs)
Old Apr 2, 2005 | 07:17 PM
casper's Avatar
casper
my car bounces off the limiter at 6500.
Old Apr 2, 2005 | 07:27 PM
SlowAssNeon
keep in mind that the factory tachs arent very accurate
Old Apr 2, 2005 | 07:54 PM
BDigital2000
my car doesn't have a factory tach at all.. so when i get the car this summer... i plan on adding one, so hopefully the one i add will be accurate
Brent
Old Apr 2, 2005 | 07:59 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
brent....what did stu say about this aftermarket tach?
Old Apr 2, 2005 | 08:33 PM
casper's Avatar
casper
Neither does mine, I have read it bouncing at 6500 on both my tach and a scan tool.
