loud squeaking noise
Old 10-21-2010, 02:50 PM
Scott145's Avatar
Scott145
Scott145 is offline
Default loud squeaking noise
i have a 98 dodge neon and when i start it up there is a extremely loud squeaking noise.This happens almost every time i start up the car and it will progressively get louder and then just stop. This also happens while im driving then slow down to a light or to turn. Then it will get louder as i speed up and stop again. Worse when cold and while raining. Anyone know whats wrong and how to fix it?
Old 10-22-2010, 01:37 PM
bg1995redneon's Avatar
bg1995redneon
bg1995redneon is offline
Have you checked your belts and brakes recently?
Old 10-22-2010, 10:12 PM
Scott145's Avatar
Scott145
Scott145 is offline
yeah checked all my breaks. going to look at belts tomorrow when i work on my car a bit more. person from auto zone said that i probably just need some belt conditioner
Old 10-22-2010, 11:05 PM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Dodge Forum Moderator
NO>>>>>Don't put that crap on your belts! Tighten it or get a new one.
Old 10-24-2010, 09:32 PM
Scott145's Avatar
Scott145
Scott145 is offline
i did that already. but it didn't do anything. still makes the same noise. why shouldn't have i?
Old 10-24-2010, 10:39 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
DOHCgarrett t3 is offline
does it happen when the defrost or AC is on or all the time? I sugest grabing a new belt.
Old 10-25-2010, 07:11 AM
Scott145's Avatar
Scott145
Scott145 is offline
Happens all the time. more when its cold or wet outside
Old 10-25-2010, 09:23 AM
bg1995redneon
If you have checked the tension for the belts and they are where they should be,then you need to start looking at the components that the belts are attached too. You could have a bearing going bad in the power steering pump, AC clutch (AC comes on when defrost is on), or alternator that is making the noise.
Old 10-25-2010, 10:26 AM
DodgeStorm's Avatar
DodgeStorm
DodgeStorm is offline
Yeah I have this problem too. Just when I first start the car, and when it is wet outside....it sounds as if the engine is squeaking. It disappears shortly after the car is warmed up. The squeaking speeds up when I rev the engine. I'm pretty sure it's not the PS/AC belt.
Old 11-01-2010, 09:30 PM
Scott145's Avatar
Scott145
Scott145 is offline
So today after waiting for cold weather again. Iv noticed that it happens more when the heat is on. but still does sometimes when its off. and its only when it starts up and i press on the break...
Quick Reply: loud squeaking noise
