leaky transmission
Will i took the car to the shop yesterday.He called me back and said when he pulled the pan there was metal in the fluid.He said he could rebuilt it for $900.I told him i only paid $300 for the car and did not think it was worth putting that much money in it.He said he could put the new seal on for $378 but i did not think it was worth spending that if he is telling me the trans is not gonna last.He charged me $150 to put it back together,So now we are looking for another car for her.
http://www.pullapart.com/ i dint know if you are lose to a junk yard but here is a link to a good one i use here in north Carolina.
Absolutely man! Get a used tranny from a junkyard with as few miles on it as you can. Should run you no more then about $400~$500 and the guy should be able to put it in for you in about an hour or two, so for less then $700, your car could be back on the road.
If you think the motor is in good or decent shape, that may be your cheapest bet. Buying another $500 car may put you right back where you are now with a different set of problems. Your call, but if the car is in decent shape, and the motor is in decent shape, then I would definitely consider it. No, you will probably not be able to sell the car and get back what you put into it, BUT, if you can drive it for a couple of years, it would pay for itself in that time........
