experimenting with engines
Old Jan 23, 2011 | 01:34 PM
advance's Avatar
advance
Default experimenting with engines
ok so first off i need to know if a dohc head will bolt and work on a sohc block but the tricky part is the sohc block is from a 2001 r/t and the dohc head is from a 98 r/t the only thing im doubting is the piston clearence. and also if i can use my old head bolts or i should get new ones. i know all the blocks are identical but still want to get others opinions.....thanx
Old Jan 23, 2011 | 07:11 PM
bulldogcheng's Avatar
bulldogcheng
yeah, everything should line up bolt-wise. not sure about how it would run though. as far as new or old bolts, you can never go wrong with new ones
Old Jan 24, 2011 | 12:36 AM
advance's Avatar
advance
Cool
today went and bolted the head up to the block timmed it and ran it through a cycle and good to go no interferance with valves so everything is good on that part and yes new head bolts will be in my near future
Old Jan 24, 2011 | 01:02 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
you can use the head bolts once after you remove them after that they should be discarded.
Old Jan 24, 2011 | 11:05 PM
advance's Avatar
advance
engine is done
Old Feb 11, 2011 | 09:36 PM
advance's Avatar
advance
Cool
its all together and runnin like a champ good to go
Old Feb 12, 2011 | 10:09 AM
22DODGE22's Avatar
22DODGE22
I wonder how to use a SOHC neon head on an old 2.2 block?
Old Feb 16, 2011 | 01:00 PM
advance's Avatar
advance
now that would be good mix if they would bolt up
Old Feb 16, 2011 | 08:07 PM
22DODGE22's Avatar
22DODGE22
I got a 2.2 motor and picked up a free neon head, It bolts right on but now I need to do some figuring on oil passages because the return on the neon is on the back of the head and one the front of the block on the 2.2
Old Feb 19, 2011 | 03:59 AM
Ghost Neon 2's Avatar
Ghost Neon 2
The 16v head on 2.2L black has been done. Check TD.com or turbo-mopar.com
