1998 neon SRT4
Old Feb 18, 2011 | 02:37 PM
22DODGE22's Avatar
22DODGE22
Default 1998 neon SRT4
I'm looking at building my own SRT4. I've recently aquired a nice 2dr neon with a bad engine to put a 2.4 in that I built in school. I heard that I'm probably going to have some wiring problems anyone one know what I might be facing?. The 2.4 I built is 10.8:1 compression, I've got Brian Crower cams, Eagle rods, JE pistons. I also picked up a custom flashed PCM.
Old Feb 19, 2011 | 09:52 PM
22DODGE22's Avatar
22DODGE22
Got it all figured out thank's to the Neons.org web site. Now I need to find a DOHC hood cuz the stock hood doesn't clear the intake cam.
Old Feb 20, 2011 | 06:46 AM
blacksunshine05's Avatar
blacksunshine05
Is this going to be an engine only or are you going to turbocharge it?
Old Feb 20, 2011 | 10:31 AM
22DODGE22's Avatar
22DODGE22
all motor, I can't put a turbo on a 10.8:1 compresssion engine. I got the motor in the car last night. I've got most of the wiring figured out. I need to find a hood that will clear the cam sprockets. The stock flat hood doesn't clear.
Old Feb 20, 2011 | 12:03 PM
blacksunshine05
That is exactly what I was going to say. Was making sure. Should be an interesting ride once it is all put together. VIS makes a carbon fiber SRT style hood that might work or I am sure you can find a non carbon fiber SRT style hood also.
Old Feb 20, 2011 | 01:51 PM
22DODGE22's Avatar
22DODGE22
I wonder if the DOHC neon sport hood will fit? I hate to spend the money unless I know. I started the car today and it sounds quite stout. Was there ever a factory limited slip diff?
Old Feb 20, 2011 | 02:03 PM
blacksunshine05
The only car with limited slip diff was the SRT-4 starting in 2004. You could always put one in though.
Old Feb 21, 2011 | 12:37 AM
NightMovesNeon's Avatar
NightMovesNeon
yes the sport hood will work as long as it has the bulge on the top on the passenger side like this
Old Feb 21, 2011 | 06:59 AM
blacksunshine05
How are you doing the exhaust? What type of exhaust manifold are you using?
Old Feb 22, 2011 | 06:02 AM
22DODGE22's Avatar
22DODGE22
I have a header and 2½" exhaust with a Borla muffler
