TURBO NEON NOT STARTING!
Old Jun 26, 2005 | 01:53 AM
R34TuRbOnEoNbOy's Avatar
R34TuRbOnEoNbOy
Default TURBO NEON NOT STARTING!
Ok i took my trany off and put a new clutch on. When i did this I put a new starter on. When i connected the wires i kinda made some sparks if that may cause anything. I put everything together and when i got to start it, it just turns and turns but no start. So i checked all the fuses and i did a spark test and there is no spark going to the engine. I put different coil pack on and there still was no spark. If someone has any idea what this could be or maybe just throw me an idea of somthing i may have not checked. THanks
[IMG]local://upfiles/8801/36787C5FA8644DE789549DC828F85FD8.jpg[/IMG]
Old Jun 26, 2005 | 06:46 PM
casper's Avatar
casper
Default RE: TURBO NEON NOT STARTING!
1st thing you should have done is disconnect the battery before you did the starter. You probally shorted something out.
Old Jun 27, 2005 | 06:03 AM
R34TuRbOnEoNbOy
YEAH I THOUGHT ABOUT THAT, THATS WHY I CHECKED THE FUSES. I DIDNT BLOW ANYTHING BEACUSE IM STILL GETTING POWER TO THE STARTER.
Old Jun 28, 2005 | 07:55 PM
R34TuRbOnEoNbOy
I may have forgoten a ground. Doesnt anyone know where all the major grounds are?
Old Jun 28, 2005 | 08:00 PM
95neonracer's Avatar
95neonracer
I know there is one running off the valve cover
Old Jun 29, 2005 | 11:19 PM
R34TuRbOnEoNbOy
Hey so where is the major ground saposed to go in the front of the neon....does it connect to engine bay/motor mount or to the tranny?
Old Jun 30, 2005 | 02:32 PM
chud298's Avatar
chud298
ORIGINAL: R34TuRbOnEoNbOy
I "THINK" it runs to the tranny, and I can't really see that well but do you have the magnum intake manifold
Old Jul 1, 2005 | 09:19 AM
R34TuRbOnEoNbOy
Yeah i do....This is pissing me off i finally get my profec b boost controller all tuned and i cant use it!!! awww
[IMG]local://upfiles/8801/A13C456943214E0DABCB4540E85C215D.jpg[/IMG]
Old Jul 1, 2005 | 08:03 PM
R34TuRbOnEoNbOy
I found out what it was...the crankshaft wires some how were ripped out of the connector that connects to crankshaft sensor.
Hey i need the connector for the crankshaft sensor.....I need the connector that connects to the sensor....The connector needs to have as long of wires coming out of it as possible. I will pay money for this part so e-mail me i need this part bad....Thanks brandon
1999 dodge neon dohc
Old Jul 17, 2005 | 03:01 AM
mnhotrod2003's Avatar
mnhotrod2003
did you get your problem solved?[sm=badbadbad.gif]
